MX6 and 3520
   / MX6 and 3520 #1
Spindifferent
Central Texas
JD 3520, JD X584
Hi Folks,
Is anyone using the MX6 on a 3520?
If yes, what are your experiences?
Much thanks!
   / MX6 and 3520 #2
What year is the MX6? Research the gearbox problems on the spanish and chinese gearboxes before you proceed. They do break reliably, and support will be nonexistent.
My dealer talked me into the MX5 and it was good until the output shaft sheared off... I'd encourage you to check out Rhino, Bush Hog, Woods, and Landpride. The track record is superior, and parts are available for cheaper than JD's proprietary specs and designs.
   / MX6 and 3520
Thanks brown.
Would be a new product purchase this year.
Have read all about the gearbox issues.
What model year was the MX5 that you used?
   / MX6 and 3520 #4
Lots written about the shaft breaks on older Deere MX rotary cutters and influenced my decision when buying a new unit. One would think Deere would have corrected the issue by now. The MX6 cutter is heavy for a 3x20 series tractor and you would likely need ballasting on the front of tractor, e.g., front weights or front end loader.
   / MX6 and 3520 #5
Mine must be 2005 or 2006 vintage--spanish gearbox. The weight of the MX6 on the 3x20 frame was the concern the dealer cited as well--said a light duty 6 or a medium duty 5 wouldn't be too much.
   / MX6 and 3520 #6
Issues have been corrected and now mx,hx and cx series come with 5 year gear box warranty. I love my mx7. Only regret is not going with a mx8 now
Brett
   / MX6 and 3520 #7
They did finally abandon the retaining bolt and went with a castle nut. The original 5 year warranty boxes from China factory instead of Spanish factory sheared off at the retaining ring as well. .. then they went to the nut. They are good cutters, just poor metallurgy and design for the output shaft trying for a clean stump jumper. Make sure its the nut--not the bolt.
   / MX6 and 3520 #8
Hope you have a fel on your tractor for front weight. On my 4520 cab without a fel the manual calls for 12 front weights (70 lbs each) to counter balance the MX6. I sold my MX6 before it had a chance to shear off the shaft, did not feel lucky enough to chance it. Other than that I really liked it as it had a nice cut.
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2025 Epic Electric Golf Cart (A51694)
2025 Epic Electric...
78'' root grapple (A53421)
78'' root grapple...
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
2009 Tahoe 195 Boat (A53117)
2009 Tahoe 195...
