MX5400 socket size advice needed
   / MX5400 socket size advice needed #1
Bullwinkle123
Platinum Member
Southern VT
Kubota MX5400HST, Z724XKW-3-54
I'm "tool challenged". My seldom used 3/8 inch socket set whose largest socket probably only goes to 11/16 inch can't handle pretty much anything on my Kubota.
Looking at other TBN threads which are often 10-15 years old, people say the Kubotas use metric bolts/nuts, I'm not sure if that's still true, and my owner manuals don't describe the nature of the parts w.r.t. metric vs SAE.
If I use my calipers in analog mode (as in, trusting my poor eyes to read it correctly, vs the digital display whose battery is momentarily shot), it looks like most of the lug nuts and loader bolts are 1". There are some larger, seemingly 1 & 1/8" nuts on the Land Pride cutter. The top link nut reads out at a strange 1 & 3/10 inches. Maybe all those apparent 1" and 1 & 1/8" bolts are really metric sizes that just read close to the imperial units, no idea.
What sort of sockets/wrenches should I have for this MX5400 tractor (with mostly Land Pride attachments)?
Also, how deep? Seems like all the tire nuts are going to need a solid inch to reach the base of the nut.
For better or worse I just ordered a 1/2 torque wrench, so I'm not really looking for 3/4 inch sets. (Until and unless I decide on a much bigger torque wrench or other gear to handle the blades on the rotary cutter). I ordered a 25-250 ft-lb wrench, most of the torques in the manual seem to be in the range of about 141-166 ft-lbs (again, rotary cutter blades aside).
re: top link nut, it's stuck, need a wrench for that, what is the real size that I'm reading as 1 & 3/10 inches?
Thanks for any advice. Remember if you reply that you're speaking to the tool impaired.
   / MX5400 socket size advice needed #2
Your tractor is metric. Just buy a set of metric sockets both in 3/8 and 1/2 as there are some big nuts and some small nuts. I use standard depth, but a set of each is nice. I think my set runs up to 22mm which covers most projects although there are some nuts that are bigger. For your top link, I'll suggest a 12" or 14" adjustable with a spud end. I have a 3/4" set but it is only pulled out every few years. The spud is used for helping align your tractor with uncooperative implements. I bought a set of large deep impact sockets at HFreight that were cheap and work for the very occasional job. I have been unable to break them using a cheater bar on a breaking bar to remove nuts on a large disk harrow. Offerings from the big box stores are ok. However, I do have a few MAC and Snap On tools and I grin and marvel at them every time I pick one up.
   / MX5400 socket size advice needed #3
My L3560 seems to have mostly metric bolts, but like anything there are a few standard on the tractor.
   / MX5400 socket size advice needed #4
If you want to convert your inch measurements to metric (mm) just multiply by 25.4. That would make your 1.3" a 33mm.
Frank
   / MX5400 socket size advice needed #5
My 5800 is all metric...some of my implements are standard. I write in permanent marker next to every nut I remove the size, saves a ton of frustration, walking back and forth carrying a pocket full of sockets, etc:p
   / MX5400 socket size advice needed #6
:thumbsup::thumbsup::thumbsup:
Also write in whatever manual you have.
For example when I started out I'd just download a Parts Manual page from Messicks and note socket sizes.
But BUY the manuals!!
They make great reading material.
   / MX5400 socket size advice needed #7
10mm, 12, 14, 17, 19, 22, 24 millimeter pretty much gets you in the ballpark for most everything you will do. Top link nut gets a 12 inch or 18 inch adjustable wrench.
I have to tell you I've had Snap-On tools for over 40 years, yes overkill for the majority of homeowners and hobby shop folks but in the 90's I bought a bunch of Craftsman sockets from Sears for a race trailer and sleds setup I had for weekends. I still have the tools. The sockets are the toughest darn things I've ever used. The thin wall 24mm socket gets used when nothing else will fit and for 20 years I've beat the things silly with a 1/2" impact gun and never broken one. Maybe you can find some older Craftsmen tools.
I can't vouch for their newer tools.
   / MX5400 socket size advice needed #8
   / MX5400 socket size advice needed #10
Tractors metric. Accessories may/may not be metric, depends on where it was made.
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
