I have a new MX5400 with the standard loader/bucket (LA1065) and 3rd function valve with a grapple. I put about an hour on the tractor a couple of days ago moving crusher run to spread around a new barn, and I've been a little underwhelmed with the lift/"breakout" strength (if that's the correct term) of the loader when scooping crusher run out of a pile of rock. This tractor replaced an '07 L4330, and the 5400 feels like it doesn't have the lift strength of the older 4330. Specifically, when trying to scoop up gravel, it basically wouldn't do anything until you took some of the pressure off the bucket (either backing up, dumping, etc). I can't bury the bucket in a pile of crusher run, and expect to roll the bucket up or lift it. I never had this issue with the 4330, especially not to this extent. My other tractors are an L48 backhoe and 7060, and while I know you can't compare it with the 7060, it doesn't seem to have the "scoop" power of the L48 either.
Specs show this tractor to have a higher lift rating than the older 4330, and I haven't tried lifting anything with a set of pallet forks...but I have been less than impressed with the loader so far. It almost seems like the hydraulic pressure itself is too low....I may need to check and confirm that the hydraulic fluid isn't low.
I guess I just expected this tractor & loader to be noticeably stronger than the L4330, but so far that doesn't seem to be the case.
