MX5100 Question
   / MX5100 Question #1
attala cruiser
Central MS
Kubota MX5100 w/FEL
I'm new to the tractor world and purchased a MX5100 with FEL, Ind Tires and Canopy. I also got a Land Pride Cutter RCR 1872. I have about 100 acres of mostly wooded land, about 15 acres to bush hog and roadways, food plots to
cut and disc. A couple of questions, anything special to do while "breaking" the tractor in? Was this a good choice for a cutter for my needs? The pasture area I have is pretty rough.
   / MX5100 Question #2
Welcome to TBN.
Read the Operators Manual.
Check all of the fluid levels before you run it much and then check them again after an hour or 2 of usage. The front axle tends to have air trapped and you get a more accurate level in the front after using it a bit.
Going by the book it says to not keep the RPMs the same for an extended period.
Do not run the engine at max RPMs for the first 50 hours.
Most people will tell you on hear to just use it. You will not hurt it. I prefer to go by the book.
   / MX5100 Question #3
Hi, I've got that same tractor, had mine for about 7 months now and love it. i did what Randall recomended took it easy for the first 50 hrs, changed the rpm a lot while using it 1500 rpm's for 10 to 15 min then jup it to 2000 rpm for the same then maby back down and then go back up.
I don't think you will have any problems with that cutter, a friend of mine has that one and it has been trouble free.
Good luck and enjoy your new tractor
   / MX5100 Question #6
Hey Attala, I'm in Lawrence County, MS. I've had my MX5100 two years now, although it has only about 70 hours on it. It's fitted out pretty much like yours -- LA844 FEL, 6-foot Rhino 172 brush hog, 6-foot box blade (brand escapes me at the moment), 4WD, R4 tires. No canopy. I have 50 acres of young (15 years) mixed pine and hardwood forest, although there are some open areas I keep mowed. I use the tractor most of the time for general utility work. It's been a great machine, and my dad, who owns four tractors on his poultry farm, lusts after it every time he comes over. :)
In addition to using my own implements, I've used my dad's disc and landscape rake for various chores. No problems at all pulling the disc or anything else.
However, there are a few weaknesses.
It likes the taste of diesel fuel. At PTO engine speeds, it'll guzzle it in a hurry. I've never measured consumption in gallons per hour, but elsewhere in the forums some have said they've measured about one gallon per hour if I recall correctly.
The parking brake is better suited for a toy than a 50HP tractor. As far as I'm concerned it's pretty much useless. I just use the FEL and/or a lowered attachment to keep it from moving when stopped on a slope.
I wish the flashers (atop the fenders) were enclosed in a heavy wire cage. They're pretty vulnerable to damage when out in the woods, and I've already broken one clean off. Cost me about 40 dollars to replace.
The hydraulic fill port is in an awkward place when you have to hoist a 5-gallon can to add fluid. A long funnel is a must, or else you're gonna dump fluid everywhere.
The tool box is too small and the latch is hard to manipulate, especially when wearing gloves. I ended up accidentally bending the latch tab (by hand), and no matter how much I futz with it, I've never been able to get it positioned just right like it was I before bent it. One of these days I'm gonna replace the whole box with something bigger.
A few tips I've learned the hard way...
When using the brush hog, I've found the tractor handles better with the FEL attached, although I usually remove it when mowing to reduce clearance. A 6-foot mower juts out a *long* way behind the tractor, and it's pretty dang heavy too, and the tractor front end gets kinda light when the mower is raised. I end up having to use the brakes to steer from time to time.
If you remove the FEL during summertime, try to detach it in a shady spot. Even if you relieve hydraulic pressure by rotating the control valve lever before disconnecting (and you should), heat from the summer sun on those black hoses will cause the fluid to expand and create pressure in the FEL lines. You'll have a hard time reconnecting unless you first relieve the pressure with a hammer and drift punch. Or you can wait until the next morning when it's cooler. :)
Move the top link to the lowest of the three connecting points. My tractor came with the top link connected to the top point, but I remember reading somewhere that that stresses the connection block unnecessarily. Makes sense. None of my attachments have needed the top link connected to anything other than the lowest point.
The tractor can be pretty tough on your yard, especially if the ground is even just a little wet. You can tear up sod pretty quickly, especially when turning hard. And I've managed to create bare tracks in areas where I've repeatedly traveled back and forth, compacting the soil and killing the grass.
Other than the nits I mentioned earlier, like I said, it's a great machine. It'll serve you well.
Cheers,
Jay
   / MX5100 Question
Jay
One other question, do you start your pto with the tractor engine at idle and slowly increase or just start it at recommended pto speed? I'm not sure exactly which is best for the tractor.
   / MX5100 Question #8
Jay
I engage the PTO after running the engine up to PTO speed. I ease out the clutch much more gently than normal, however.
   / MX5100 Question #9
I do the opposite, i start the pto at about 1000 to 1200 rpm with the attachment raised. Then i take off in what ever gear i'm going to use while lowering the attachment and increasing engine speed to full pto 540
   / MX5100 Question
Thanks again for the helpful advice. This is the first tractor I've owned and I'm learning the ropes...
2023 Icon I40L Electric Cart (A50324)
2023 Icon I40L...
Chery 6' 10 Drawer Workbench (A50121)
Chery 6' 10 Drawer...
2023 FORD TRANSIT CARGO VAN (A52141)
2023 FORD TRANSIT...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
1998 John Deere 544H Articulated Wheel Loader (A50322)
1998 John Deere...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
