MX5100 Front axle pivot zerks
   / MX5100 Front axle pivot zerks #1
crystallake
Bronze Member
Jonesboro, AR
MX5100HST
Last weekend I did some grease and lube work around the tractor. Greased the front pivot, taking out the relief plug and pumping grease in until it came out the relief and then a little more to get good clean grease inside. Then moved on to the next zerk to the rear of the front one, on the drive shaft. The thought came to me...where is this grease going?? There is no relief port, I do not see any coming from a seal. Just learning and wondering. I looked up the parts diagram and it looks just like the front bushing but with no exit hole. Anyone know the answer?
   / MX5100 Front axle pivot zerks #2
When you get some hours on it and the pivot loosens up a bit, you'll see the grease oozing out around the axle boss. I only give mine a couple strokes, it don't need a lot, not much movement there.
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
IH 470 Disk (A50515)
BUYERS PREMIUM & PAYMENT TERMS (A51219)
BUYERS PREMIUM &...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
