MX5100 Cruise Control wont't Hold
   / MX5100 Cruise Control wont't Hold #1
Johnret
Missouri
Kubota MX5100 w/Loader, Kubota B7500, John Deere F935
Does anyone know how to tighten up the cruise control on the MX5100, mine won't hold at all. It work for about 1 year now won't hold.
Thanks:confused:
   / MX5100 Cruise Control wont't Hold #2
Is your parking brake on?? This happened to me once, and the parking brake was on just a little bit, so the cruise was completely loose.
OK, so I got my MX5100 fixed. Like the L3800 there is two locking nuts that when tighten apply pressure to the return mechanism. I have no way of knowing how much pressure should be apply to the locking nuts, but I did tighten mine down a bit and started cutting my pastures and it held like brand new for 3 hours. I would recommend that is these nuts are tighten to the point passed holding the cruise control in place when engaged. To then back them off till you notice a slight creep back to not set and then tighten just past that point. I figure that is going to be the only way of setting it so it doesn't hurt anything but still holds the cruise when set.
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
1043 (A50459)
1043 (A50459)
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
