MX 8 Deere Rotary Cutter Needs a Home
   / MX 8 Deere Rotary Cutter Needs a Home #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
We just got this 2003 John Deere Model MX 8 Rotary Cutter in. The cutting Width 96". It has reinforced double deck design capable of cutting up to 2" diameter brush. Non seize--self adjusting slip clutch is standard and the Min. HP Requirement 40. Transport width is 102" and weighs approx. 1700 lbs. Features a Semi-Mount hitch with hydraulic cylinder for rear of machine with a Center Gearbox rated at 120 hp. and the outside boxes rated at 75 hp. The blade tip speed 15,739 ft./min and it does have Front and rear chains. $4200. Ken Sweet
UNUSED LANDHONOR PR-12-72W 72" HARLEY POWER RAKE (A54757)
UNUSED LANDHONOR...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2007 Ford F-150 Ext Cab Pick-up Truck (A53422)
2007 Ford F-150...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
