Mushy hydraulics?
   / Mushy hydraulics? #1
KanakaRick
Truckee, CA
KIoti DK50S
I'm sure this has been covered before, but Tractorbynet won't let me do a search, so I will ask again: On my Kioti DK50C the bucket hydraulics seem a little "mushy". It's not as responsive as I am used to on other tractors. The motions are
rather slow and somewhat hesitant. Anything i should look for? The reservoir is full. When using the plow blade everything worked well and was very responsive, but for some reason the bucket seems slow.
   / Mushy hydraulics? #2
Couple things to check
Disconnect and reconnect all of your quick couplers on your loader.
Check to make sure that any of your extra rear hydraulic port levers are in the center/ off position.
Change your hyd filter make sure it is OEM, some people have had problems using non oem filters and not getting good flow to their pump.
Test HYD pressure with a test gauge on one of the quick disconnects.
7021 (A50322)
7021 (A50322)
Swict 84" Bucket (A50121)
Swict 84" Bucket...
NEW Fork Extensions (A53002)
NEW Fork...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2013 Infiniti M37 Sedan (A50324)
2013 Infiniti M37...
2013 Haulotte 4527A (A50120)
2013 Haulotte...
