Murray Transaxle Replacement
   / Murray Transaxle Replacement #1
bill46
Belgrade, Me
Murray
The hydrostatic trans-axle in my 1996 42910x92C,Peerless prt #794643 has slowed down to the point where it no longer wants to move. It will still go forward, but very slowly and nothing in reverse. I noticed oil dripping from the bottom of the non serviceable transmission. There is no replacement available from Peerless, or the manufacturers agent.
Otherwise this tractor is in good shape. Will a Tuff Torq K57 fit and work in this tractor?:confused:
   / Murray Transaxle Replacement #2
Bill46 - check here - Pat's Small Engine Parts - looks like they have one - listed as part # TEC794643
TECUMSEH PEERLESS TRANSMISSIONS AND HYDRO PUMPS
I ordered mine from here a year or two ago - was exactly as specified. I order most of my parts from here now - they are an excellent operation and usually the best price
I have a 2001 Murray that has been unstoppable - I destroyed the transaxle by dragging a chain harrow on steep hills - basically "boiled" the oil to the point it was spewing out of the relief valve. This caused the symptoms you described. However, I actually replaced the transmission fluid in it - even though it is not serviceable, there is a port were you can remove and replace the oil and Tecumseh actually sells the correct fluid. This bought me two years before it started going bad again - so then I just replaced the whole unit
Let us know how you make out
2006 KENWORTH W900L (A53843)
2006 KENWORTH...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2006 TerraGator 8104 (A53473)
2006 TerraGator...
PALLET OF 15-BLACK GROUND PROTECTION MATS. 4FT X 8FT (A53843)
PALLET OF 15-BLACK...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
