Multiple sets of tires
   / Multiple sets of tires #1
Ryansweatt2004
West gardiner maine
2017 kubota L3901 HST
Hey everyone. I've had my kubota l3901 for about 7 months now. I bought it brand new with R1 ag tires specifically for the purpose of having the added traction when skidding logs through muddy trails in the woods and for the added traction when dragging a box blade. However I'm finding I could really use a set of turf tires as well for working and traveling around my house where the lawn gets torn up most of the year with my r1 tires. Just wanting to see if anyone else out there has thought about or actually bought multiple sets of tractor tires to swap out for different seasons or uses?
   / Multiple sets of tires #2
I f the budget will stand it , why not ? If you are mowing with it a designated mower may be the same money .
   / Multiple sets of tires #3
Do you need both front and rear or just the front? I suspect the fronts do the most damage from turning.
Yea the front R1 tires definitely do the most damage. I don't use it for mowing because I have a dedicated mower for the lawn. My main use for the tractor up till recent has been snow removal, road grading and tree work/getting firewood out of the woods which the R1 tires have been excellent at doing. Now though I'm doing a fair bit more work up close to my house and neighbors houses where things like rocks, firewood or any other heavy objects need to be moved without tearing up the lawn. Budget wise it's a little expensive to buy a set of turf tires unless I find a decent used set on Craigslist. Mainly just looking for feedback on if anyone else keeps more than one set of tires for different times of the year or different types of jobs and if it's a big pain to change tires as the needs change.
   / Multiple sets of tires #5
I can't comment on two sets of tires but I have kicked around the thought of turfs on the front of my 2400H since it is used for mowing. I am concerned about finding tires the correct diameter so that when I use the FWD they don't fight the rear to much. Also do turf tires have the sidewall strength for loader work? I have no desire to install turfs on the rear though.
   / Multiple sets of tires #6
Changing tires is a pain, especially when they are filled. Most guys pick their tires by what will work best for the majority of their uses and accept the draw backs for the other occasions. I know there are some folks with the little sub-compacts that have multiple sets but tires that size are much easier to handle. Having a backhoe mounted is really handy for lifting the rear with the stabalizers.
I'm sure that someone is going to come along and suggest R4 as a mid way between turfs and ags, the "best of both worlds" type of deal. More accurately, they are the worst of both worlds. Traction not much better than turfs in the mud, still tear up sod like R1s and just plain suck in the snow. Where they do shine is in their puncture resistance.
   / Multiple sets of tires #7
turn your tires around and they won't tear the yard up as bad
   / Multiple sets of tires #8
Turning the tires around (without changing the rims) will ruin the front axle on a four wheel drive. My L245DT had the warning in the operators manual. I switched and they were right. Offset was bigger with the tires on the rim as shipped.
   / Multiple sets of tires #9
how will it ruin front axle, no different than widening the stance of the tractor
   / Multiple sets of tires #10
That's a good question. How would tread direction have anything to do with how the 4wd works?
JOHN DEERE 461R LOT NUMBER 61 (A53084)
JOHN DEERE 461R...
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
2015 GALYEAN 180 BBL STEEL VACUUM TRAILER (A52472)
2015 GALYEAN 180...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
