Multiple Quotes in Post ???
   / Multiple Quotes in Post ??? #1
scott_vt
Super Member
east wells,vt
1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Afternoon Guys,
Would someone be kind enough to tell me how to make a single post with multiple quotes from different posters in your reply post ?
Thanks in advance !
   / Multiple Quotes in Post ??? #2
scott_vt said:
Afternoon Guys, Would someone be kind enough to tell me how to make a single post with multiple quotes from different posters in your reply post ? Thanks in advance !
I click on the Quote button in the message that contains the most information I want to quote.
For all the other quotes, I do it manually by copying the text and adding {quote=userid}text{/quote}
Perhaps others have a better method.
   / Multiple Quotes in Post ??? #3
scott_vt said:
Afternoon Guys,
Thanks in advance !
I just did the above by opening two browser windows to the same thread. I used the QUOTE button in Scotty's post and then used it in MikePA's post. Then, I copied MikePA's quote to this post and put it under Scotty's. If I wanted to do quotes from 10 different posts, it would get a little tedious, but it saves having to do a bunch of careful bracketing and such. This works great for quoting from multiple threads.
Another way for multiple quotes from a single thread is just to type a single template like MikePA did. Copy and paste it several times into your post and then scroll down to the text and copy the quoted material and paste it into your template. Then modify the username for each quote and you're done.
Two ways to skin a similar cat.:)
Thanks Mike :)
{quote=jinman} {/quote}
Thanks Jim :)
{quote=MikePa}I click on the Quote button in the message that contains the most information I want to quote.
Perhaps others have a better method{/quote}
I guess I failed that test !!!:(
   / Multiple Quotes in Post ??? #6
Scotty,
Change the curly brackets that MikePA used to square brackets. He used curly brackets to demonstrate only. If he had used square brackets or you use them, it will look like this:
   / Multiple Quotes in Post ??? #7
I just use the button at the top in the reply window, it adds the "quotes" for you. It's the yellow box that looks like it has writing in it.
Then I just scroll down to the previous post's and copy the text I want to quote then paste it between the quote code.
   / Multiple Quotes in Post ??? #8
kennyd said:
I just use
the button at the
writing in it.
Then you can do quotes within quotes within quotes... :)
jinman said:
Showoff!...;)
jinman said:
Scotty,
Lets try this ! :)
OK for the record this is MikePa method ! But with Jims help ! Kenny I couldnt find any little yellow box ! :confused: But this works so Im happier than..... never mind ! :) Thanks all !
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Ground Breaker X Backhoe BH80X 3 Point Hitch Attachment (A51573)
Ground Breaker X...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
