Multiple Fuel Mix Ratios
   / Multiple Fuel Mix Ratios #1
ky8t
On Lake Livinston in Texas
Kubota BX-2230
I have several two cycle power tools, some of which recommend a 40:1 fuel/oil mix while others specify 50:1. I believe I have seen 32:1 also. Do I need to make two different cans of fuel, or can I just use one mix for all? If so, what mix is best for all?
   / Multiple Fuel Mix Ratios #2
My shindawa weed eater is 40:1. The dealer doesn't sell the 40:1 mix any more. They said 50:1 was OK so that's what I use in it now. Makes it easier because my chainsaws are 50:1.
   / Multiple Fuel Mix Ratios #3
Buy Amsoil Saber 100/1 synthetic and mix it at 80/1 with 93 octane fuel and use it in everything... problems solved.
   / Multiple Fuel Mix Ratios #4
Used Opti-2 at their specified ratio in all types equipment since 1999. No problems or issues to report related to fuel mix. Not cheap, but it's worked well IMHO.
   / Multiple Fuel Mix Ratios #5
If you want to use 50-1 mix and get it right, mix with 8 tenths of a gallon. I used 50-1 in my back pack leaf blower when it was new and ruined the motor. lucky for me, they fixed it under warranty. Aaron
   / Multiple Fuel Mix Ratios #6
I second using Amsoil Saber at 80:1. I have a Stihl BR600 back pack blower that requires 50:1, a Stihl FS90R trimmer that requires 50:1, a Stihl MS390 chainsaw that requires 50:1 and a cheap Weed Eater hand held blower that requires 40:1. I use Amsoil Saber at 80:1 mix w/ 89 gas in all of them and they run great. They actually run and perform a lot better on that mix then they did on their recommended mix. I've ran that mix for the last few years and haven't had any problems, and don't expect too. Most guys in the lawn care industry run Saber at 80:1 because of cost efficiency, and the fact that they only have to carry one mix. Go over to Lawnsite.com and read about it if your interested.
   / Multiple Fuel Mix Ratios #7
We run all our STIHL here on the farm (028 Super chain saw, FS76 Brushcutter & BR340 Backpack) at 25:1 using non-STIHL oil as the mfg recommends in each owners manual. Dealer says they all can be run at 50:1 like their newer '4-strokes', but that seems a bit lean to me.
They are 20+ years old and have not complained.
   / Multiple Fuel Mix Ratios #8
One shop told me to lower the ratio in hot weather when working them hard so they run cooler.
As noted there is no such thing as 40:1, 50:1, 100:1 oil per say because that value is determined at the time of mixing.
Since we use Super Tech Outboard 2-Ccel TC-W3 engine oil in the diesels and sometimes gas four strokes for fuel system lube I am thinking of mixing it 32:1 and using it in everything.
All gas I bring home for storage is non ethanol 93 octane and treated with Sea Foam at the pump due to it being used mainly in small engines.
   / Multiple Fuel Mix Ratios #9
http://www.utextension.utk.edu/publications/spfiles/sp268-I.pdf
Read especially the last paragraph.
This tells me that the one-mix oil as designed is sufficient when mixed at 2.6 oz to one gal of fuel, that that is enough oil to properly lubricate the engine.
I used the one-mix fuel for about 21 years, and I don't remember any engines damage cause by this ratio. Some of you say that more oil makes it better, for what. Are you trying to out guess the engineers who have done a whole lot of testing.
Even the 100 : 1 Amsoil oil is mixed at 2.6 oz per gal of fuel.
AMSOIL - Saber? Synthetic 100:1 Pre-Mix 2-Cycle Oil (ATP)
2018 Terex RL4 Towable Light Tower (A42742)
2018 Terex RL4...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
2018 Ford Transit 350 Cargo Van (A42742)
2018 Ford Transit...
PORTER CABLE 150 PSI AIR COMPRESSOR (A45333)
PORTER CABLE 150...
2011 John Deere Z Trak Pro Z925A 60in Zero Turn Mower (A42744)
2011 John Deere Z...
New/Unused 12X20 Steel Carport (A44391)
New/Unused 12X20...
