Multi-Grade Oil for 1950 Ford 8N Advice Needed
   / Multi-Grade Oil for 1950 Ford 8N Advice Needed #1
timebak
Bronze Member
Our farm near Muscle Shoals, Alabama...FINALLY!!!
RK37SC & John Deere 2030
What multi-grade engine oil would you use in an 8N Ford tractor that would be good for all year usage? I'm thinking maybe Rotella or Delo 400 in 15W-40. What think y'all? This tractor doesn't get used more than about 10 to 15 hours per year, if that much.
Thanks in advance,
Tim
   / Multi-Grade Oil for 1950 Ford 8N Advice Needed #2
I sell New Holland 15W-40 and Conoco Phillips Fleet Supreme 15W-40 all the time for N series tractors. Can't think of the last time anyone asked for 30W for a tractor.
   / Multi-Grade Oil for 1950 Ford 8N Advice Needed #3
We always use 10W30 in these old machines.
Chris
   / Multi-Grade Oil for 1950 Ford 8N Advice Needed #4
I've been using Mobil Clean 5000, 10W-30 in my old tractors, a 1950 8N, 1940 Farmall H, & 1948 Farmall Cub. Cold starting is much easier than when I used 30W
   / Multi-Grade Oil for 1950 Ford 8N Advice Needed #5
Either mentioned will work.
The 15w40 will carry a bit better oil pressure and would be better suited for hot summer work. The 10w30 would be a good choice for colder weather, or if your engine isnt worn out too much or rebuilt recently, it will have no problem maintaining pressure.
   / Multi-Grade Oil for 1950 Ford 8N Advice Needed #6
i run 15w40 in all my old gassers.
if I lived in an *arctic* area, and she had double digit hot oil pressure i'd probably go 10w30.. then again.. 15w40 may be needed to get then double digit pressures.. :)
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
WOODS RT48.30 LOT NUMBER 234 (A53084)
WOODS RT48.30 LOT...
RHINO X1808 LOT NUMBER 43 (A53084)
RHINO X1808 LOT...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
