multching blades F2000
   / multching blades F2000 #1
LouNY
Super Star Member
Greenwich, NY
Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Evening all;
Has anyone used mulching blades on their Kubota front deck mowers in particular the F2000 with the 72" deck, RC72-F20.
What blades did you use?
And where did you get them?
Any gator blade numbers?
I couldn't find them for the older deck with the 15/16 center hole in the blade.
Lou
   / multching blades F2000 #2
Lou I put Oregon "Gator" blades on my F-2000 BUT it's only a 60"
fwiw p/n 392-025 20,5" X .948 center hole. I don't remember who I got them from (on line) but it tool a bunch of searching and remember that the center hole was the hard part to match. I bought 2 set's and just went out to the shop to get the number and saw a note to myself that I need to make 2 passes with the grinder off each end of the blades before mounting them.
Thanks I found a set for the 60" but not the 72"
New/Unused 78in Quick Attach Grass Fork Grapple (A51573)
New/Unused 78in...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
INOP/NON-RUNNING 2006 Mack CV713 Granite Truck, VIN # 1M2AG11C56M039887 (A51572)
INOP/NON-RUNNING...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2012 JACK COUNTY 130 BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
