Mule 3010 fuel pump relay?
   / Mule 3010 fuel pump relay? #1
newt
My fuel pump went out so I replace it ,the fuse is good so I need to check the
relay. But were is it on a 2003 3010 ? Help please
I ordered a service manual 1o days ago and it's still not hear
   / Mule 3010 fuel pump relay? #2
kawasaki mules web site has a parts catalog showing the relay for your model year , look under fuel pump , looks like it may bolt on the frame rail ( 1 bolt ) 3 wires coming out of it .
   / Mule 3010 fuel pump relay? #3
not sure if that mule has the same engine as the hpx has .i know one of the mule models does .when i first bought my gator it suddenly shut off and wasn't pumping any fuel. me and my buddy thought it was the fuel pump or a fuse but it turned out to be a bad sensor mounted to the bottom of the carberator bowl. it send a signal to the pump to pump fuel when it went out the pump wouldn't come on .something to check into maybe. after reviewing the specs on the mule engine i see it is the same engine that was on my 04 hpx.
Found it :)
it's on the driver side of the fuze box
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
2020 RoGator RG1300C Spreader (A53342)
2020 RoGator...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
2017 AUTOCAR YARD SPOTTER / TRACTOR (A52576)
2017 AUTOCAR YARD...
