Mule 2510 Axle Bearing Replacement
   / Mule 2510 Axle Bearing Replacement #1
Riddler
Sonoma County, CA
New Holland TN75VA, New Holland TC45DA, New Holland TC18
I need to replace the driver's side rear axle bearing on my well used Kawasaki Mule 2510 4x4. If I am reading the repair manual correctly, it looks as if I have to detach the rear leaf springs and brake lines and drop the axle bracket so that the axles can be separated from the drive shafts and then slid out of the axle hubs. Can anyone who has done this before confirm that I need to get the axle out of the hub before I can replace the bearing(s), and that dropping the axle bracket is the only way to get the axle out of the hub? Thanks.
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2014 Isuzu NPR-HD Landscaping Sprayer Truck (A50323)
2014 Isuzu NPR-HD...
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52748)
John Deere 1110...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
