kcender
Platinum Member
I recently bought a B2620 with a 54 inch deck.I read reviews on this setup and a lot of people mentioned that the clippings from the mower were quite long which is what I found.I figured mulching blades would help even if I wasn't using a mulching kit.When I called the dealer he said Kubota did not offer a mulching kit or mulching blades for this deck.He did have a new set of mulching blades for a 54 inch fine cut deck off a BX tractor.These blades looked to match up in length,width, and thickness but the hole in the center was too small.I bought these blades and took them home.I tried drilling out the holes but the steel in the blades was too hard for HSS drill bits.I was able to get the holes machined out no problem.I have to say with the mulching blades the deck gives a cleaner cut with finer clippings.I will definitely be using these blades from now on.
