Mulcher and synthetic hydraulic oils
   / Mulcher and synthetic hydraulic oils #1
yellowdogsvc
Platinum Member
S. Central TX Hill Country
Anyone use synthetics in their skid steer or CTL mulching applications? Is it worth the cost for synthetics? I have a dozen attachments so if I switched to synthetics, it would be an investment to swap out the oil in every machine to prevent mixing (or is that a problem?)
   / Mulcher and synthetic hydraulic oils #2
I do not use synthetics. The trade off criteria is: for the additional cost is it worth it, does it give you the extra protection for the additional time frame that it make it economical? Lots of discussions go on about that topic.
If you have an oil/hydraulic testing protocol in which you regularly take samples and send them off to a lab so that you can track the results of time versus degradation that might help justify the cost of switching but if not then I would not do it but that is just me.
If you do not switch everything at the same time then you will quickly dilute the synthetic and you will lose any benefit that you might have gained. I know my new Fecon head just took nearly 20% of my reservoir. If you have a 20 gal reservoir or so with synthetic and 5 gallons in 5 different implements after the first implement is installed you have a reservoir with 80% synthetic. After the second implement is hooked up your dilution factor changes again and so on. Very quickly you have mostly normal fluid and very little synthetic left in you main unit.
Think of it this way 5 gal in 5 units and your 20+ gallon reservoir. 25 gallons normal and 20+ gallons synthetic. After several implement swaps you have about 45% synthetic and 55% normal fluid.
That is forgetting the fact that many say that you should never mix fluids and to ensure a complete drain before switching over.
(INOP) MURRAY BOGGIN MOWER TRACTOR (A51247)
(INOP) MURRAY...
2017 Caterpillar D5 K2 LGP (A53473)
2017 Caterpillar...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
2005 National RV Inc. Dolphin LX RV (A53117)
2005 National RV...
