Chipper Mulch Dog 8" Chipper, Mulcher
   / Mulch Dog 8" Chipper, Mulcher #2
I bought one of the first 8" they sold on EBAY. Here is a link to pictures of it after I got done putting it together...
http://www.tractorbynet.com/forums/...s-15.html?highlight=jinma+chipper#post1167402
Without getting into a long and drawn out argument or discussion, it is basically a 'Jinma' type 6" chipper with a bigger mouth [opening is larger to allow for larger logs to be chipped, about 10" wide by 8" tall], and a bigger diameter feed roller to help feed in the larger stuff. The cutters are identical to the 6" chipper, which is about 10" long. The chute on these units is longer to help support the weight of the bigger logs, and maybe to help in the safety department by keeping you farther from the roller and cutting blades, and that is why they put the brace under it in the front. All these units are front heavy and tippy when not hooked onto your tractor, and with the longer chute, these units are even worse. These units also use basically all the same parts as the various 'Jinma' type chippers, and you can source parts from various places. I don't like the setup it came to disengage the feed roller, and modified mine quite a bit. I have used several different chippers in the past, and went with the bigger unit on purpose. I will probably never chip much stuff bigger than 4" or so, but if you have ever worked a chipper, you know why bigger is better. There is every shape of branch out there, and with all the side branches and how they flare out, it comes to a shoving and twisting match to get some to fit in the mouth. If you want to get a 6" on EBAY, check out BEDST. Also do a search on JINMA on this site, lots of reading stuff. Good luck, Jerry.
Looks like some of these sold for in the $600 range. Is he just taking a beating on Ebay or is that normal for these?
   / Mulch Dog 8" Chipper, Mulcher #4
I'm not sure. You got me there. Most of the reputable dealers on this forum are up around $1600 for the 'Original Jinma'. The BEDST on EBAY is presumably 'the first one to send one to China' to get built, and comes with an upgraded PTO shaft and upgraded roller driveshaft with universals, and is around $1400 last I checked. I've seen 6" like this guy is selling go for up to $2600 on adds, which are looking for suckers as far as I can tell. I bought mine for a little less than $1160 plus freight. I think he is taking a loss at that price, but who knows. Maybe he is getting them shipped in for $500, but I doubt it. About any Chineese 'brand' you buy, you are getting basically the same design, with a little fluff here and there. Try to get it cheap, then you can afford to put some money into it and make it last. They are built fairly heavy, but sure wouldn't pass any US safety standards. Somebody said....'don't lick the paint' :)
(2) ROLLS OF MISC CARPET (A54757)
(2) ROLLS OF MISC...
2006 VOLVO VNL (A55745)
2006 VOLVO VNL...
2021 Toyota Rav4 AWD SUV (A55853)
2021 Toyota Rav4...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
pressure washer (A55973)
pressure washer...
HYDRAULIC MOTOR AND PUMP ON A SKID (A55745)
HYDRAULIC MOTOR...
