MT372D seat
   / MT372D seat #1
Weedsnthorns
Lake County, Fl
Mitsubishi MT372D
has anyone had experience modifying a lesser expensive seat on this model tractor. Just spoke to Valley Power and priced out a new aftermarket {200.00}. Dont want to sound cheap but .....
   / MT372D seat #2
I'm sure Bill has lower priced seats . However I got mine from Southern Global. Don't remember exact price but under $75. It was a universal seat that came with mounting brackets that you put on at the right width . I see them on E-Bay often .
   / MT372D seat #3
I don't believe you spoke with me. The correct price for that seat is $125. Bill
   / MT372D seat
Thanks Bill,
Does this seat mount without any modifications? I was told by your representative that it doesnt have the rubber bump stops. If not do you have them? Does it come with the pin for attachment?
Thanks,
Keith
   / MT372D seat #5
I will supply springs and hardware to mount springs on the side pieces of the tool box. I've mounted mine that way. The rubber bumpers don't provide enough lift. The pin is not included. However, I have found that the holes on mine have gotten slightly enlarged over the years and the pin doesn't fit quite tight enough. Thus the seat rocks a little. I'm going to drill the holes out a little and use bolts with lock nuts and washers to remove the slack. Using lock nuts, I can tighten the nuts just enough to remove slop and still be able to raise and lower the seat. Bill
2018 Bobcat E50 (A50123)
2018 Bobcat E50...
CAT 257D (A50123)
CAT 257D (A50123)
PNEUMATIC GREASE UNIT (A53843)
PNEUMATIC GREASE...
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
