MT372 Water in Steering Box and how to refill box
   / MT372 Water in Steering Box and how to refill box #1
Nazrat
My MT372 started oozing gear lube from the steering box. I discovered that it had some water in the bottom when I dug in. I assume that the seal around the steering shaft is probably shot. Is that right under the steering wheel, or do I need to pull the column to access it?
Also, to refill the box I was going to remove both top bolts from the plate on the right side, then fill through the highest hole until lube oozed out of the 2nd highest one. Is there a better way to fill it?
Thanks,
Tad
   / MT372 Water in Steering Box and how to refill box #2
Add more water!?:D
You may be able to get the shaft seal to hold the gear lube better if you can get to it, clean the outside then spray it where the seal contacts the shaft with Brakleen. It's not a permanent fix, but it can work depending on the age/condition of the seal and the shaft.
   / MT372 Water in Steering Box and how to refill box #3
There is a seal right under the steering wheel at the top of the column. You are on the right track for filling it. I filled mine with a small pump normally used to fill outboard lower units.
Thanks. Using one of these: Fluid Lubricant Pump type pumps it took 23 pumps to fill it, in case someone is curious.
-Tad
   / MT372 Water in Steering Box and how to refill box #5
That^s the ticket.
Ok, where can I buy that shaft seal online? Is there any other way water could be getting into the box?
-Tad
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
2015 INTERNATIONAL LONESTAR SFA 6X4 ROAD TRACTOR (A52706)
2015 INTERNATIONAL...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
48 Inch Grapple Root Bucket (A55218)
48 Inch Grapple...
