MT2201D hydraulic screen
   / MT2201D hydraulic screen #1
wayneL
northern vermont
MitsubishiMT2201D
Could anyone tell me if the MT2201D has a screen for the hydraulics and where it is located I found the filter but was wondering if it has a screen somewhere also I don,t have a manual yet and this is my first tractor. Thanks Wayne
I checked my tractor but couldn,t find anything that looks like that on mine, I have lost all hydraulics while I was tilling the other day. I lost them 3 different times while tilling on the loader and the tiller the last time they didn,t come back. I had a fella tell me it could be a plugged screen somewhere in the hydraulics so trying to find where it might be. Iam ure greatfull for anyones help. I don,t know much about tractors but this site looks like a real good place to learn. Thanks for taking the time to try to help, Wayne
   / MT2201D hydraulic screen #4
Wayne, try Valley Power Products in Roanoke, Va. They are VERY knowledgeable and helpful. But not open weekends. I have an mt2501d and they have babysat me through many problems and provided parts. Good folks. 1-800-609-5110. The 'Satoh Parts' mentioned above is them.
Bill thanks I,ll call them Monday.
   / MT2201D hydraulic screen #6
Wayne, Just looked at the parts manual that I bought from VPP and it covers your MT2201D and my MT2501D. I purchased it so that I would not only know what the insides of my tractor looked like but when I called the parts folks, I would be able to talk about the same 'apples and oranges'. It gives a great break-down of all pieces of the tractor with fairly good drawings and parts names and numbers. Do you have a loader? If so, what brand? There is a place in Hillsboro, Oregon called 'Small Import Tractor Supply' that has a website and can help with your tractor stuff, too. Have you found the tractor junk yard called 'West Kentucky Tractor Parts'? Always more to learn.....
Thanks Bill I did get my hydraulics back 4 different times today it seems like I have to rev the throttle for quite some time to get them to work after shuting the tractor down and starting it again there seems to be no hydraulics til I rev the throttle again everything works fine when the tractor is left running I wonder if my pump could be getting bad. Yes I do have a loader on the tractor, doing everything by trial and error so I guess it will take a little time and really don,t know if I got enough time just turned 61 a few days ago.:laughing: I will order a manual Monday if you come up with any ideas send them my way I can use all the advise I can get. Wayne
   / MT2201D hydraulic screen #8
if there is a plate there with 4 bolts that may be where its at. check your hydralic fluid level. the pump coupling. the control levers being stuck in the wrong position. dont use the 3 point hydraulics lever and the front end at the same time. good luck finding the problem.
Bill forgot to answer you on my loader, the loader is a Allied Mod 195. I did have my hydraulics on the tractor this morning but same deal I had to rev the throttle for quite some time before everything started working, I worked about 30min. with the loader and it seemed OK. I shut everything down and waited about 30min. and tried it again same deal nothing til I rev the throttle for quite a while and then the hydraulics are fine. Mit still can,t find anything like that on my tractor but right in the front under the seat is a plate will 3 bolts that looks like it could be something, I should have a manual in a few days don,t know if I can wait that long before tearing something apart, but Iam going to try.:laughing::laughing: Thanks Guys
   / MT2201D hydraulic screen #10
where does the hydraulic line starts from your resorvour? the metal line from the case to the pump?it is coupled to the case with a banjo bolt the filter screen should be opposite that. the 3 bolt under the seat may be the high pressure bypass valve.
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2014 SHOP BUILT  DISCHARGE MANIFOLD (A53843)
2014 SHOP BUILT...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
CASE INTERNATIONAL 695 TRACTOR (A51406)
CASE INTERNATIONAL...
377811 (A48836)
377811 (A48836)
