MT20D glow plug system?
   / MT20D glow plug system? #1
Rebeldad1
Veteran Member
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
I checked my glow plugs with a meter. Key on in glow plug position there is no voltage. The wire from the glow plugs to the relay is ok. The other larger wire to the relay gets 12V with key on. I now have two small wires. One gets battery power to the relay with the key in glow plug position. Where does the other go? How do I know the relay is bad? and where do I get a replacement relay?
Also would like to get a wiring diagram for this tractor!!!
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53473)
2019 Energreen EVO...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
2009 Peterbilt 335 Cab and Chassis Truck (A51692)
2009 Peterbilt 335...
