MT18D Manual and Specifications
   / MT18D Manual and Specifications #1
nme
Ramstein, Germany
Mitsubishi MT18D
Hi folks,
I recently made a nice bargain and got a Mistubishi MT18D.
Sadly, all the labels are in japanese... Does someone have an english manual for this tractor or can at least give me some hints on
-using the hydraulic side panel with the two dials (one read and one green, plus two switches , one labeled "auto")
-the box under the seat with the three switches
-where to select 4WD
Additionally, does anybody know, if the MT18D came in a 3 cylinder 15kW version?
thanks!
nme said:
Hi folks,
thanks!
some problems solved:
controls the hydraulic for just one arm of the 3point. the dials can be used to pre-set left/right arm position and the quick-select this position.
lever on the lower left side of the front console, just right of the clutch. front position is 2WD
and just in case some people wonder what oil filter etc to use: the MT18 has the Mitsubishi K3E engine, which is used in other machinery like forklifts, marine vessels, ....
thanks for the link.
for the mt18d it says years 86-92, but the local official mitsubishi agri retailer claimed, that the mt18d was built 90-95
so who is right? :)
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
(INOP)1985 GRIZZLY 80 ATV (A51247)
(INOP)1985 GRIZZLY...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51691)
2005 Ford F-750...
