Mt180hd hydrolic filter
   / Mt180hd hydrolic filter #1
alfdoc
Damascus Oregon
Mitsubishi mt180hd
Dose any one know the pt# of the spin on hydraulic filter? Any help would be a great help.
   / Mt180hd hydrolic filter #3
Hi guys. Old topic but same question for me here. Need to do a complete servicing on my new Mitsubishi MT180HD and I could not find the reference of the hydraulic filter (not even on the filter itself, just plain white, rust spotted....). Thanks for your help !
   / Mt180hd hydrolic filter #4
You may be interested in this operators manual ( doesn't cover the HD model though) https://www.agroinform.hu/data/foru...ishi_mt160_180_instruction_book_optimized.pdf
If you need a service manual, I would suggest buying this one Service Manual - Ih-s-235 International Harvester Case IH 235 | eBay
1282528C1 Pretty certain this is the filter you need, it is the filter for a Case 235.....a Mitsubishi made tractor and similar to your MT180. Google that part number and you will find the expensive OEM Case filter or cross references to other brands.
On edit- probably should have included this manual as well I&T Shop Manual Mitsubishi MT21 MT21 MT3 MT3 MT25 MT25 MT18 MT18 I have this one and the Case manual- they are both good but the Case manual covers more.
   / Mt180hd hydrolic filter #5
Hi Kernopelli
Thanks for your message. I did search for the reference given, but it's unfortunately a different filter from the one I need. Actually, dimensions are the same, but thread size is 1 1/8 on your reference, while I need a 7/8 (22mm ish).
Anyone with a M180HD who can provide me with a filter reference ?!! The only one I find with a 7/8 thread are shorter (135mm instead of 180mm, so lower filtering capacity...).
2000 GROVE RT640E MOBILE CRANE (A51406)
2000 GROVE RT640E...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54313)
2019 KENWORTH T680...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
