MT180HD generating problems
   / MT180HD generating problems #1
johan3400
Western Illinois,just this side of heaven
Kubota L3400 FEL
I have an MT180HD which is at full load on the alternator at all times. This causes the tractor to overheat. I can run the tractor all day if i turn off the ignition switch. This is such a great little work horse I would like to run it the right way. Hope someone has a suggestion to a fix for this.
   / MT180HD generating problems #2
If it is overcharging, your regulator probably needs replacing. I can supply you with a new or used regulator & most other parts for your tractor.
UNUSED RAYTREE REDM32-32" EXCAVATOR DRUM MULCHER (A51248)
UNUSED RAYTREE...
POWER BREEZER PORTABLE ELECTRIC EVAPORATIVE COOLER (A51248)
POWER BREEZER...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
