MT1601d Clutch Problem
   / MT1601d Clutch Problem #1
jleliason15
Manti
New Holland Ts110
I bought a Mt1601d off eBay. It runs great other than the clutch has to be pulled up every time I push it down. It is very stiff in both directions. Is there any way to loosen it up without tearing the whole thing apart? The spring on the pedal is not the problem. Thanks in advance for any ideas.
   / MT1601d Clutch Problem #2
You will have to split. The input shaft is rusty and the clutch or release bearing is sticking on it.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
2020 Isuzu NPR Heil Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
2012 TRAVIS 39FT DUMP TRAILER (A53426)
2012 TRAVIS 39FT...
2000 Mack CH613 Day Cab Winch Truck (A53117)
2000 Mack CH613...
2005 Ford F-750 Crew Cab Heil 5 Yd Mason Dump Truck (A51691)
2005 Ford F-750...
1994 Fiat Allis 65-B Motor Grader (A52384)
1994 Fiat Allis...
