MT 55 with skid steer quick attachment?
   / MT 55 with skid steer quick attachment? #1
kevincook
Platinum Member
k
I have a standard skid steer quick attach auger that I want to put on an MT55. Can I make this work?
Thanks,
Kevin
   / MT 55 with skid steer quick attachment? #2
At the bottom of the standard QA are 2 sets of holes/slots. If the narrower set fits the lock pin location of the MT55 (mini-QA) then it will lock on. If you want to convert the auger for permanent use, once the auger is mounted to the MT weld an angle iron at each side of the QA to act as alignment guides so it is easier to hook up nest time.
When ever using an auger on QA always raise lift arm up high enough to look underneath the QA to make sure the pins are locked in place before curling the auger down or turning it on.
Thanks. I need to look at my plate to see if there is a narrow set of holes for the locking pins.
If the holes do not line up can I just drill new holes?
Kevin
   / MT 55 with skid steer quick attachment? #4
Here are the dimensions of the fullsize plate, it shows the other holes.
And a picture of the mini plate.
Cat TH407C Telehandler (A53472)
Cat TH407C...
UNUSED INDUSTRIAS AMERICA SK72 72" HYD BRUSH CUTTE (A51247)
UNUSED INDUSTRIAS...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
2020 KUBOTA RTV...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2015 FREIGHTLINER...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
