Oil & Fuel MT 372
   / MT 372 #1
lndfaust
North East Pennsylvania
Mitsubishi MT372
Can ayone tell me how much oil the transmission / hydraulics take? The sticker on the fuel tank is worn and unreadable. What happens if you overfill. Larry
   / MT 372
Thanks for your reply oliver28472, Do you think overfilling could be the cause of my problem with hard to get in gear when running? I just changed thr gear oil out and replaced with universal tractor fluid.-- filled it up pretty good. About an inch from filler plug. Larry
   / MT 372 #4
More likely a clutch adjustment problem or worse a clutch problem. If the engine is running and you have to grind the gears to get them to engage the clutch is not fully disengaging. Though on a geared transmission like my old
IH 424 if the gears stopped with the gear teeth stopped directly on top of each other you would have to hold a little pressure on the gear shift and let out on the clutch a little to spin the gear a little. Give some more detail of the problem and see if we can offer anything else.
   / MT 372 #5
Was it grinding before you added the oil? I agree with dex3361 on the clutch adjustment.
   / MT 372
Split tractor today. Looks like pressure plate is falling apart. Throwout bearing so so. Gonna change the whole shebang while I got it apart. Larry
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2019 Dodge Journey GT SUV (A50324)
2019 Dodge Journey...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
