MT 372 Gear case spewing lube
   / MT 372 Gear case spewing lube #1
skylarkguy
Platinum Member
Dallas Oregon
Mitsubishi MT372, Ford NAA
I've got an MT372. I had been using it all summer with no problems. It then sat for several months under cover. Recently I started it with no problems but as I started driving gear lube started flowing out of the rubber boot on the shift lever. I pulled the filler plug out (while running) and it came shooting out of that hole too. So clearly the gear case is building up pressure for some reason. Any thoughts? I was running a brush hog at the time, and had put on ag tires from turf, which is the only change I'd made recently. It seem this must have a vent in it somewhere that is plugged...but where?
   / MT 372 Gear case spewing lube #2
Has it been rained on? Could have water in the case.
Thank for the Idea. It hasn't been in the rain. It gets parked under a metal shed which stays dry (even in Oregon winter). The gear oil looks good...not cloudy or gray like it is contaminated with water.
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A52377)
2017...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
2006 KOMATSU WA200-5 WHEEL LOADER (A52705)
2006 KOMATSU...
