I have a 2022 MT 357 with 190 hrs. I was driving across town to mow some property and I notice the right front tire moving in and out from front of tire to back of tire. It was very subtle, not a violent wiggle or shimmy and could not be felt in the steering wheel. The left side was also moving but not as much. The movement is best described as toe-in, toe-out. You really have to look hard to see it. I lifted the front of the tractor off the ground will the loader. The front tires have front to rear play at the knuckle at the end of the steering cylinder the tie rod end is attached to. I'm not exactly sure of the design there as a rubber boot covers it. Not sure if it is some type of ball socket set up or type of u-joint. Strangely there is no grease zerk at this location only on the actual tie rod end. On the right side I would guess there is a 1/2" of in and out movement in this area which translates to the tire having close to an inch of front to back play. Maybe a 1/4" on the front left. I don't see any unusual tire wear but I'm sure it can't be good on them. I'll contact my dealer for warranty. I may see if they can just get me the parts and change them myself. They are a great dealer to work with. The LS parts diagram shows it as the tie rod end assembly, part #40462718. I need to get this rectified before it totally fails.
I thought I would put this out there so other owners with this style steering may want to check theirs. If you do a check let us know if you have any play in this area.
