MT 2501
   / MT 2501 #1
Zorigto
Chita, Russia
MT 2501 Mitsubishi
Good Afternoon Members
Recently had a problem of oil running from the front axle.
The tractor is 1996 model MT 2501.
Was looking for the spare parts to replace damaged seal ring, but could not find out the number of the part.
The question is if there is anyone who could help with manual or spare part number?
If you do have any suggestion, will warmly welcome.
Zorig
   / MT 2501 #2
My 1650 had bad leaks on the front axle - after a lot of searching I found a parts manual and it actually showed a good exploded view of the components, including the seals --- but, it was in Japanese with the numbers, but they wouldnt even cross to anything. The exploded view did help with getting an idea of how it was assembled and was a help in disassembling.
So I went ahead and took it apart and found the seals had perfectly legible numbers which I was able to easily google up several sources for them.
So you might just go ahead and get it apart and may find your numbers also.
   / MT 2501
We indeed took it apart but found no numbers, or it was completely warned out, no idea. That's the reason we started to look for manual in order to get the number
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
CATERPILLAR D6T XL CRAWLER DOZER (A52705)
CATERPILLAR D6T XL...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
