mt 1801 hydraulic pump replace/repair questions
   / mt 1801 hydraulic pump replace/repair questions #1
somanytractors
atlanta, ga
several
I need to replace the hydraulic pump, or get it repaired.
The tractor is an mt1801 with a 4 cyl diesel.
I can get a new pump for $550, or a used one for $350.
A bit more then I wanted to spend on a used pump and I don't really need new, but I don't know what I can replace it with, or if it can be rebuilt.
I don't know the manufacture of the pump but it does have a number gp-3757a
Is a kit available for this pump, or is there someone that rebuilds them?
If not does anyone know where to get a used one that will fit at a reasonable price?
   / mt 1801 hydraulic pump replace/repair questions #2
I bought a new higher GPM pump from NCW Tractor Parts, LLC As best as I remember it was under $350. If your old pump just needs a new seal, they can probably supply it for a few bucks.
Hi Kernopelli.
Thanks for the info. $350 for new is definitely reasonable.
I haven't been to that site before.
I don't see a pump listed for the mt1801 but I'll probably give them a call. Its quite possible that they just don't have it listed.
   / mt 1801 hydraulic pump replace/repair questions #4
I have a spare for a MT372D. If it's the same one I'll sell it to you for what a paid for it, $240. I thought i needed one bit turns out i was having a different hydraulic issue.
Hi.
Thanks for the offer. Unfortunately, I don't know what pump fits what.
   / mt 1801 hydraulic pump replace/repair questions #6
I have the same tractor and am puzzled where you check the hydraulic oil level? Can't find a dipstick or check plug just a filler
hi.
mine is an mt1801 with a manual transmission.
the fill cap, next to the shifter, has a dipstick on it.
its a round rod about 8" long. the full mark is about 1" from the bottom of the stick.
hope this helps.
   / mt 1801 hydraulic pump replace/repair questions #8
Hmm mine has the fill plug on the shift cover but it's just a rubber plug about an inch in diameter, no dipstick on it. Guess I will measure a stick about 8 inches long and use that!
Thats what I would do.
Its just hydraulic fluid. it wont matter if its a little high or low.
If its too low you'll know by the hydraulics not working correctly.
   / mt 1801 hydraulic pump replace/repair questions #10
Hello, I see at one time you were looking a hydraulic pump for a Mitsubishi MT1801. I was wondering if you able to locate one? I am in need of the same thing.
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
