MT 125 Hydraulic pump
   / MT 125 Hydraulic pump #1
dhale63
2019 LS MT125
I have a 2019 MT 125 with the Yanmar engine. It has about 30 hours on it. I understand that the hydraulic pump is situated under the seat and positioned about directly underneath your left thigh. Is it normal for there to be a constant humm coming from that area? I'm not talking about normal hydrostat whine that I am used to with other my other hydro equipment. This is a humm that is constant and slightly changes pitch with throttle up or down. I have checked all my fluid levels and they are all perfect. I have not hit my first 50 hour service so the filters are all original. It may be perfectly normal for this tractor but any reassurance/advice would be greatly appreciated.
   / MT 125 Hydraulic pump #2
I would call my dealer tomorrow and ask them, and document it. Good insurance!
Probably normal though.
   / MT 125 Hydraulic pump #3
The pump is located on the left side of the transmission directly above the axle, directly above the hydraulic filter. More like under your left butt. I never heard any "humm" from mine, only the hydrostat whine.
   / MT 125 Hydraulic pump #4
Have you noticed any performance issues, creeping, etc? My 125 has had serious hydro pump issues and has spent weeks in the shop
   / MT 125 Hydraulic pump #5
Nope , never any issues with the hydraulics. After about 100 hrs +/-, the pedals wouldn't return fully, but it was a simple adjustment of the tension spring.
   / MT 125 Hydraulic pump #6
I had the pedals not returning after 12 hours. The damper tied pedals had broken a weld and was not returning the pedals to level.
   / MT 125 Hydraulic pump #7
My 125 is a year and a half old now and has 70 hours on it and not a bit of hydraulic or pump issues.
   / MT 125 Hydraulic pump #8
Mine is about 6 months, closing in on 100 hours. I've been listening for this since I saw the thread a while back. I can't hear anything unusual over the engine noise and the usual Hydro whine.
   / MT 125 Hydraulic pump #9
Mine had 176 hours at 2 years, no hydraulic problems whatsoever. Strong as new. Never any weird noises, the hydro whine actually got quieter.
Has the OP even checked back? Wonder if he took it to the dealer to get it checked?
   / MT 125 Hydraulic pump #10
My dealer said he had seen this type issue with mine only once before, about a year and a half earlier. Said he’d probably sold 50 of the 122/125 size TLBs and were otherwise never had an issue. Pretty sure mine was a factory lemon. LS actually did me right and replaced the tractor with a new one. Got a call from corporate office in North Carolina telling me they would make it right.
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
JOHN DEERE 700M LOT NUMBER 35 (A53084)
JOHN DEERE 700M...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
