Mowing Mowing with CUT on Spetic System Lines?
   / Mowing with CUT on Spetic System Lines? #1
tillboy2001
A mowing question got me thinking about this. Do you think it's safe/advisable to mow on top of the septic system chambers with a John Deere 4120 w/finish mower? I say chambers because this is the type of setup we have, installed with the new house in 1996: Septic Chambers Wondering if soil compaction will be an issue...or any other problems?
Another question. We have the tank sucked out regularly, but I've noticed on at least 2 of the lines, all along the line - about 50 feet long, the soil is saturated and very soggy from the sewage seeping through. Anyone know what the 'problem' could be? Or is it of no concern? Soil type is fairly heavy clay. It's been like this for about 2 years now.
My thinking is it's not a clog problem because obviously the liquid is making it's way to the lines and the sludge is staying in the tank. It SHOULD be a well draining system because everything is downhill. The tank is even below the basement level of the house because of the way the land lays. And then the lines are lower down in the lawn from the tank.
Photos attached. If you look in the middle of the photo, you'll see a post on the other side of the fence with a bluebird house on it. That's where the tank is.
In this photo, the lines are out in the main part of the lawn. The tank is to your right, just up the hill a tad.
   / Mowing with CUT on Spetic System Lines? #3
I think I would contact the manufacture. My lines are a rock bed so I don't worry about it at all. In fact the company that installed it told me to mow it even with my heavy tractor. But to me yours looks like it has a dead space to it and the tunnels could collapse as they are plastic. Can't say I have ever seen one like yours.
murph
I might need to ask someone about the soggy soil. Maybe the guy that installed it awhile ago is still around (he's kinda old and probably retired now). He did excavating for a living.
Found this interesting bit of info on their site - Didn't think they'd want ANY trees nearby, but...
"Encourage the right plants. Remove trees such as
willows that like “wet feet.” Their roots may penetrate
and damage the leachfield. Grow grass or ground cover
over the septic system to prevent soil erosion. Plant
beneficial trees such as pines near the leachfield to
absorb water."
   / Mowing with CUT on Spetic System Lines? #5
Check out this site:
Think Tank Septic Forum
The whole site is a wealth of information on septic systems.
You can post questions there and the site operator will usually answer them via email in a few days.
They've stopped the question asking due to overload...but I did see some useful info. Kinda bothers me now though /forums/images/graemlins/frown.gif I probably have a combination of these two:
Failure of the Septic System from Overload or Poor Distribution
If the soil surrounding and below the drainfield remains moist and not wet, the aerobic bacteria will dominate the drainfield and things are working fine. If the soil becomes saturated with sewage effluent or water, anaerobic (water breathing) bacteria from the effluent take over the drainfield. Then the treatment stops. The soil surrounding the drainfield becomes abnormally clogged with organic particles. The normal dark bacterial film (biomat) found below and around normally operating drainfields, becomes thick and totally waterproof. The soil stops absorbing effluent and ponding above ground usually occurs. Failure is also often accompanied by a "sewage odor."
A completely failed system generally must be replaced in a fresh location. If the drainfield is abandoned for a year or more, it probably will recover. In replacing a failed gravity drainfield, it is wise to put in a valve (bull run valve) to allow switching back to the old drainfield as a backup.
A septic system can be deliberately made to fail simply by turning on any tap in the house and leaving it running for a week or so. The excess volume of effluent will flood and fail the drainfield by killing the aerobic bacteria in the drainfield. This is why it is always important to repair hissing (leaking) toilets and even dripping taps in a home on a septic system.
Poor distribution of the effluent in the drainfield causes local patches of failure, reducing the effective area of the drainfield. This is why pressure systems are more reliable than gravity systems. Pressure distribution is almost always required in complex systems and poor soil conditions.
Failure of the Septic System from Poor Soil
Generally the best soil in which to build your septic system is undisturbed medium sand. Very fine sands, and darker organic (loamy) soils are second best. Silt, a very fine soil with a smooth texture like talcum powder is even less absorptive. There is simply less space between the particles to hold and pass water.
Clay, and extremely fine clay-like soils are poorer for septic systems. The poorer the soil, generally, the larger the drainfield due to the slow rate of absorption. Finer soils formed from ancient stream and lake beds can be compacted, and layered. Fine bands of silt and clay can spoil otherwise good sandy soils.
Also, coarse gravelly soils can be too porous allowing the flow of effluent from the drainfield to penetrate deep into the soil too quickly. This places the effluent below the plant root portion of the soil. This upper soil zone is where treatment must happen because of the presence of oxygen and aerobic bacteria.
Even when soil is good, it may not be deep enough to allow a system to be built (usually a minimum of four to five feet deep). Septic systems in shallow soil above a layer of solid rock, or above a shallow water table may not be approved by the local health department. Sometimes an alternative system such as a mound may be allowed if soil is too shallow.
If the soil is poor, or too shallow, why not bring in some good soil to replace it? Once ordinary dirt from a site has been disturbed or moved, it will not support proper septic functioning. The soil will fail in a few weeks. This is just one of the mysteries of soil. This applies to natural sand, dredging spoils, potting soil and all imported dirt. Once soil is left undisturbed for a few thousand years, microorganisms and other large and small forces of nature create a condition called soil structure. This naturally changes the soil making it suitable for use as a treatment medium. A designer or soil expert is trained and experienced at determining soil structure by throwing a hand pick at the soil face, and by feeling (texturing) the soil and other tests. Most home-owners and do-it-yourselfers would not be able to recognize poor soil structure and should not determine system size in areas known to have poor soil.
   / Mowing with CUT on Spetic System Lines? #7
Driving a CUT, truck, auto, or any other heavy vehicle over any part of any septic system is NOT to be recommended.
A normal sized yard sized homeowner lawnmower is not a problem though.
   / Mowing with CUT on Spetic System Lines? #8
</font><font color="blue" class="small">( Driving a CUT, truck, auto, or any other heavy vehicle over any part of any septic system is NOT to be recommended.
)</font>
I don't have this problem because i don't have a leach bed.
This is the only way to go.
Works better and is trouble free.
   / Mowing with CUT on Spetic System Lines? #9
I drive over my lines all the time when mowing with the B7800. I haven't had any problems yet. I'm not going to buy a small rider just to mow the leach field. It hasn't even compacted really. I try not to drive over it unless I'm mowing. If I'm using the loader I go around it or if I'm going to the other side of the property I'll go around it.
No leach bed? How so? I could do that if I had city sewage (we almost got it but they stopped down the road)...but are you using a different system?
2024 New Holland T8.410 MFWD Tractor (A52128)
2024 New Holland...
Willmar 4300 Wrangler Loader (A52128)
Willmar 4300...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2022 CATERPILLAR 926M WHEEL LOADER (A51242)
2022 CATERPILLAR...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
John Deere Quick Attach Bale Spear (A50514)
John Deere Quick...
