Mowing Mowing with a GPS
   / Mowing with a GPS #1
Toolguy
Platinum Member
West Michigan
B3030
I mowed my lawn today with a GPS mounted on the the tractor. I have a Kubota B3030 with a 60" MMM. My lawn is approximately 1.5 acres of mostly wide open area with trees that are bedded or have mulch rings around them. I can just drive around them and no extra trimming is required. Here are the results that I found interesting. My mowing speed at full HST pedal in Medium Range is about 5 MPH. Including backing up, I traveled 4.39 miles. The elapsed time was 1 hour and 5 minutes. I also took the tractor for a short trip down our paved road at WOT in High gear and found out that top speed is 11.5 MPH.
When I was done mowing I had a track of my travels on the screen that showed where I had been. It was an almost perfect outline of my yard that showed everywhere I had driven. Pretty cool. If you have a portable GPS it might be fun to try ity out yourself the next time you mow.
   / Mowing with a GPS #2
Actually between the mowing itself, the cruise control, the stereo headphones, and the ballgame running on the overhead TV console I have no time to look at a GPS. ;)
Unless of course it does the driving for me......
   / Mowing with a GPS #3
ToolGuy, that's pretty cool. Thanks for sharing. I figure by the mph chart on my finder that when I mow (kinda low tech, huh?) that the length of my drive is right at 10 miles.
   / Mowing with a GPS #4
Which GPS do you have?
They make a wrist unit that displays speed, elasped distance.. Petty cheap..
Dan
   / Mowing with a GPS #5
I like the ability of my cheap little GPS to calculate the internal area in acres of a circular path that you travel. I'm very bad at guessing the size of a parcel by eyeballing it. So it's nice to have the GPS handy to be able to say ok, that parcel is 1 acre, that one is 5, that one 7, etc etc. On the other hand, I'd be afraid to look at my lawn mowing path....does the GPS have a "chicken with head cut off" mode? :D
   / Mowing with a GPS #6
that is a great idea using it to calculate area. That would help with a lot of things.
I was thinking from the thread title that this was an autopilot thing. Sounds like PineRidge needs one of those with all he has going on in the cab! :)
   / Mowing with a GPS #7
Cab, I have no cab, I like the bugs that get caught in my teeth. :D
   / Mowing with a GPS #8
PineRidge,
Do you have the tv mounted to your canopy or were you just joking on the TV? Might be a punch line I missed. I am pretty good at that some days.
   / Mowing with a GPS #9
Tim I have no TV in the tractor, I was just pulling your leg a bit.
   / Mowing with a GPS #10
I heard you were going to install a TV, but you'd have to move the soft-serve ice cream machine, so you decided against it.;) :p
2016 Ford Fusion SE (A50324)
2016 Ford Fusion...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
Bush Hog (A50322)
Bush Hog (A50322)
