Mowing Mowing TC45
   / Mowing TC45 #1
natural
Elk River, MN
I posted this in the Case Section but never really got an answer back. Does anyone finish mow with a TC45. I am concerned about the weight. Checking in for my boss.
Nate
   / Mowing TC45 #2
Yes, i mowed with a tc 45 da for years and w/o any problem but i had turf tires.
Now i have a Nh tce with a 16*16 and again no problem weight +- 1900 kg
But if you will have a good result please mow slow with the hydro i mowed in I-rabbit
(6-7 mph)
   / Mowing TC45 #3
I do contract mowing for municipal athletic fields with a TC40D and 84 inch landpride rear discharge finish mower. I have the turf tires which provide good floatation. I even use it to mow my own lawn when I'm in a hurry. The tractor and mower combination does a good job and the rear discharge distributes the clippings well. For profesional fields, reel mowers are the was to go but for town budgeted fields a rear discharge mower is adequate. The tractor can easily handle a larger mower deck. There are 90 and 100 inch single mowers available. Best of luck.
   / Mowing TC45 #4
I have finished mowed with a TC-40D for 2-1/2 years now. Mine has R4s and does a pretty decent job of cutting. You just don't want to get out on the yard with a Class III machine when its still soft.
   / Mowing TC45 #5
I use a tc 40d and 84" rear discharge also. R-4s with 200lb on each rear wheel. I mow about five acres of my own yard. No problems with weight or lawn damage. Of course I don't mow when it is really soft or turn real short with 4whl. drive engaged. Does a great job..........
Gene
PALLET OF MISC LINCOLN ARC WELDER, AIR COMPRESSOR (A51244)
PALLET OF MISC...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2016 KUBOTA RTV-X900 UTV (A51243)
2016 KUBOTA...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
2013 Isuzu NPR Eco Max Box Truck (A47384)
2013 Isuzu NPR Eco...
