Mowing questions
   / Mowing questions #1
SaltySteve
X300R
Hello all,
I just moved into a new to me house in south Louisiana sitting on 5 acres of which it is approx 80% clear (grass). I am currently using a JD X300R (42") to cut it which takes 6.5 hours run time. It will also have to handle other light tasks such as grading a 300' driveway. The machine actually cuts it very good if you have the time every week to do it. I need a little advice on upgrading my mower and more importantly, how much weight is considered too much when it comes to mowing lawn. I have been considering a JD 2520 with a mmm but would really like something a little larger. Once you go larger than the 2520 the weight shoots up another 1000lbs. Am I placing too much emphasis on this weight thing? Also I considered a zero turn but ruled it out because of the driveway maint issue. I really can't afford a ztr and a tractor.
Steve...
   / Mowing questions #2
I personally wouldn't want to go bigger than that for an all around tractor to mow the yard. No, I don't think you are placing too much emphasis on weight. What may look OK just driving across a lawn, can cause significant compaction over time as well as added stress on your grass.
Just my opinion.
   / Mowing questions #3
weight's probably not an issue unless you live in soft areas. see my avatar.. that's a 95 hp tractor with a 15' mower that I mow my pasture with... no ruts..
you are right on the cusp where I'd say jump from 25 hp to 30ish hp. would be nice to pull a 5 or 6' mower and mow faster.. to do that I'd want a 30 ( + ) pto hp machine.. 30 will do it for 6' as long as you don't let it get like 7' tall.. etc.
soundguy
   / Mowing questions #4
I was in about the same situation as you Steve. Wore a couple of mowers w/ 42" decks out until I could afford to get a tractor. It was taking me about 6 - 7 hours (sometimes longer if it were high) to mow the grass. I bought a New Holland TC-24D. It has a 60" MMM. Took the time down to about 4 - 5 hours. Didn't save me as much time as I had hoped, but at least my repair bills are now non-existent. I've had it since June 2003, and it now has a little over 1300 hours on it. So I still spend a lot of time mowing. I'm thinking something that would allow you to go up to a 72" or 84" deck if you want to finish mow it all. Maybe a nice zero turn and an older used tractor for the gravel driveway?
   / Mowing questions
maybe I should clear this up, when I say grass I mean Lawn. There is no hay to make here....
   / Mowing questions #6
When we got the Kubota we have, one of the questions we asked, are we planning on mowing the lawn with it? If we had decided yes, we would have went with the smaller frame B or BX Kubota. Almost the same hp, but much lighter so we could safely mow over drain field (we have very shallow drain field due to clay soil). Since we were not mowing the lawn with the new tractor, we went with the bigger frame (heavier, with FEL, Rimguard).
I've seen some very nice JD tractors in the same size as the Kubota B and BX that would handle the mowing and driveway chores very nice.
   / Mowing questions
I hear you on the wear and tear. I really need my X300R for the bagging close to the house so I don't want to wear it out then have to buy a new one and a tractor. I figure I'll buy the tractor now and save my 300. If it just saves me a couple of hours mowing thats fine with me. My main concern is that it will last a while.
   / Mowing questions #8
If you are going to keep your lawn mower then I would agree with Soundguy and go with a bigger tractor. I use an L5030 and M8540 for mowing close to my house, just not my yard.
   / Mowing questions #9
I have a JD GT245 that we purchased from the previous owner of our home. It has a 54" deck. We live on 3 acres that is pretty open with not many obstacles. I can consistently mow it in 2 hours including trimming one of the ditches and under the grandkids swings/fort. So I think anything with a deck size more suitable to your lot size is going to result in quite a bit of time saved.
If I mow with the Kubota with the 60" deck, it is definitely saves some more time because 1. it is a bigger deck; 2. it will mow quite a bit faster; and 3. the mower doesn't shut off every time you have to back up. But I would guess the savings for me would be like 20 minutes or so.
The Kubota info says the B2x20 series weighs 1550# which I assume is without any attachments and dry of fluids. If the ground is dry when I mow, you can hardly see where I have been. If it is reasonably moist, I see some tire tracks, but they are usually gone within a day or so.
My neighbor traded his JD GT245 he had for a ZTR after he saw me mowing with the Kubota (mower envy). I actually think his ZTR tracks up his yard worse than either of my tractors when the ground is wet. And as you mentioned, all it will do is mow.
   / Mowing questions
I was looking at the various ztr specs and it seems that if you go with a commercial model with a good size deck that the weights were running between 1200 and 1450 lbs. That is quite a lot of weight on those small tires. I bet it would track it up a little while damp.
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2002 Chevy 3500 Dump (A47384)
2002 Chevy 3500...
2020 Ford F-150 XL (A50120)
2020 Ford F-150 XL...
