Mowing Mowing question.
  • Thread starter kingoflawns
  • Start date
   / Mowing question. #1
K
kingoflawns
Guest
How many sq. ft. per hour can a B3030 cut with a high quality rear finish mower, say a 72" woods? Normal cutting conditions, 4" grass, open athletic feilds. Just looking for approximates her'e. Thankx Scott.
   / Mowing question. #2
You didn't give a forward speed, so I'll assume one for you. You can adjust by multiplying this number by the ratio of your actual speed to 6mph.
6 ft wide x 6 mph = 4.3 acres/hour
If you only go 5mph, multiply 4.3 by 5/6.
If you go 7 mph, multiply 4.3 by 7/6.
That's with no turning, etc. You can probably figure on about half that.
edit: Oops, you asked for square feet: 190,080 sq. ft.
   / Mowing question. #3
king -
doing some "edumacated guesstimating" /forums/images/graemlins/grin.gif here's some math:
72" wide = 6 feet
1 mile = 5280 feet
1 "mowed mile" = 31,680 ft^2 (~ 0.73 acres)
soooooooo.....
I looked on the 'Bota website - B3030 listed "top speed" at 12.1 mph (3 range). By posts I've seen here - most folks seem to prefer mowing in "MID range" (I have 2 ranges - mow in HI) - so lets *assume* top speed in MID is 8 mph...
8 "mowed miles" = 253,440 ft^2 (~ 5.82 acres)
If you are truly going to mow "playing fields" (ex soccer / football) - then this may be possible.
I'd say a more conservative estaimate - mowing at 1/2 top speed: 6 mph - this gives you:
6 "mowed miles" = 190,080 ft^2 (~ 4.36 acres)
For comparison - I mow @ 2 acres (@ 43,560 ft^2 / acre = 87,120 ft^2) in @ 1 hour - and I have a 54" (4.5 ft) wide MMM (so my "mowed mile" = 23,760 ft^2)
So by my calculations I should be averaging:
(87,120 ft^2) / (23,760 ft^2/ 1 mph) = 3.66 mph
That seems about right for my *average speed* - my lawns are not equally smooth - and I need to go slow around rocks - or through bumpy sections. I know I can zip along @ 5 - 7 mph in the smooth flat sections.
Hope that helps,
Dan
   / Mowing question. #4
cp -
dang! I was "composing" while you were "posting" - I did my own math though! (I didn't peek - honest! /forums/images/graemlins/cool.gif ) Glad we came up with the same number!
Always two ways to skin a cat.... /forums/images/graemlins/grin.gif
Dan
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
BUSH HOG BH114 4' ROTARY MOWER (A51243)
BUSH HOG BH114 4'...
Stehl Tow Dolly (A50514)
Stehl Tow Dolly...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
(INOP) 2011 MACK CXU613 T/A ROAD TRACTOR (A51243)
(INOP) 2011 MACK...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51244)
KNOW BEFORE YOU...
