Snow Mowing,plowing snow??
   / Mowing,plowing snow?? #1
70boss
Bronze Member
Madison Wis.
Had a B7500
I am looking for your collective wisdom on the abilities of various machines to do the following:
Mow grass, on uneven terrain, just bumpy
Plow snow, or sno-blow a 750' gravel driveway
grade and level a gravel driveway to eliminate the effects of water erosion after rain.
I am looking for 1 machine, to replace my current inventory of 3 machines.
Specifically, I am looking at the JD 755/855/955, or the new 4100/4200 series, as well as the 790.
Thanks,
Rob
   / Mowing,plowing snow?? #2
I just bought a 4100 HST at the beginning of this month. It has the 410 loader, 60" belly mower and turf tires. I too was looking for a single machine that could do everything I need to do. I have 11 acres. About two acres are grass that needs to be cut. The rest is pasture for the horses. I would occasionally need to move material, drag the pasture, etc. I also have a half mile paved driveway to plow.
I have not yet used the mower but I am sure it will handle what I have. We had 8" of wet, heavy snow on Saturday night. I had no problem plowing with the loader. This included steep hills and flat terrain. The 4100 labored a little on the steep hills. A couple of times I had to drop it into low going up the hill and then it was no problem. I just set the bucket level to plow and go. The loader requires you to make a couple extra passes but it was no big deal. The advantage of plowing with the loader is you can easily move big piles that accumulate.
I was very impressed with how the tractor performed. Traction was no problem with the turf tires. No need for chains.
   / Mowing,plowing snow?? #3
70boss,
I'm sadden /w3tcompact/icons/shocked.gif to read Kubota B2410 nor B2710 was mention,for they are grand tractor and well fit your needs.
The JD4100 is fine unit..oops sorry guys I had to check one out w/ all the talk about them here on the board /w3tcompact/icons/blush.gif..and I can see why its becoming a popular tractor.
You may want to try JD4100 out at a dealer,thats of coarse after you visit a Kubota dealer. /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
I like the Kubotas as well, from the prices I have seen, they also cost quite a bit more. The B2710 costs a lot more than the JD790. I like the B7500, but it doesn't have position control on the 3 point hitch....pretty dumb, my 50 year old 8n has position and draft control.
   / Mowing,plowing snow?? #5
70boss,
I could never understand why Kubota didn't offer power steering on the B7500,you would have thought so when tractor owners traded up and power steering was a must on there list.
   / Mowing,plowing snow?? #6
Thomas, I think the B7500 does have power steering; just doesn't have position control. Am I wrong?
Bird
   / Mowing,plowing snow?? #7
Bird,
Your 110% RIGHT...and thanks for reminding me I have to start wearing my darn glasses. /w3tcompact/icons/frown.gif
Its the B7400 thats doesn't have power steering.
   / Mowing,plowing snow?? #8
70boss,
A gentleman just inform me the B7500 does have power steering,sorry about the bad info.
The B7400 doesn't have power steering
It does have power steering, if it had position control, i would have already bought one. I don't need a large compact since I have convienent access to a larger (2640) John Deere with a bush hog that absolutely eats trees and shrubs. I plow my driveway with a 4x4 Polaris Sportsman 500 ATV, and it does a very good job. I just want to get rid of 3 machines and replace them with 1.
   / Mowing,plowing snow?? #10
70Boss, I have a gear drive 4100 with a JD front blade and a 413 rotary cutter for my fields. I have about 10 acres, and a gravel drive about 850 feet long. The front blade does a pretty good job on the drive. I looked at the 790 as well. With 4wd and the front blade, it was quite a bit more money. The blade and frame on the 790 is a lot heavier duty than the 4100 with the 54" JD blade. I haven't tried any finish mowers yet (just put the lawn in last summer), but the 413 does a good job with the fields. My original thought was that I would rather have a 6 foot brush hog, but the 4 foot 413 lets me spend a bit more time on the tractor. That wasn't my original goal at all, but I have so much fun with it that I would like to cut it down to a 3 foot pass. All in all, I think if I knew last year what I know now (this is my first tractor other than a garden tractor) I would have gone for either the 790 or the 4200. I typically have to plow snow early in the morning before sunup, and the 54" blade is just shy of wide enough to do one pass down and back up.
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2022 BARFORD TR8036 MOBILE SCREEN (A51242)
2022 BARFORD...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
UNUSED FUTURE MINI SKID STEER HYD 4IN1 BUCKET (A51244)
Diamond 5' Heavy Duty Excavator Mower (LIKE NEW) (A50774)
Diamond 5' Heavy...
