Mowing Mowing in reverse on steep hills
   / Mowing in reverse on steep hills #1
norcal
I have pastures which I would like to mow. About 2 acres of the pastures are on steep hills - 25-30 degree pitch. I plan on mowing while reversing up the hill, and mowing while going forward down the hill using a brush cutter. I was told by a dealer that I should not mow while reversing up the hill. Something about the cutter could get "pinched", or it could end up "driving the tractor", throwing it off balance, and possibly causing it to go sideways. making the tractor unbalanced, perhaps enough to cause it to roll. He also mentioned that when in reverse the PTO and cutter are also rotating in the opposite direction? Hence, the sharp part of the cutter is not being utilized, rather the cutter is just beating the brush with the non-sharpened part of the blade?
This is new to me - I am looking at purchasing a late model or new Kubota, Deere or NH.
   / Mowing in reverse on steep hills #2
Find another dealer fast!!! /forums/images/graemlins/blush.gif His BRAIN may be working in reverse.
   / Mowing in reverse on steep hills #3
Don't you have room to turn around at the top? My concern would be accumulating the cut-off brush in the mower and jamming it up. The other possibility is not having proper traction if you manage to back over the trimmings.
PTO reversing with the tractor? Did his office smell kinda like burning leaves and rubber?.....................chim
   / Mowing in reverse on steep hills #4
Norcal, that's a new one </font><font color="blue" class="small">( rotating in the opposite direction )</font>. /forums/images/graemlins/laugh.gif I don't know of any tractor ever made that did that in reverse, but that's not to say there haven't ever been any, but you sure won't have that with the tractors you're considering. And I mowed steep slopes just as you're suggesting. Hard to believe a "dealer" would tell you what you're saying this one did.
   / Mowing in reverse on steep hills #5
Just to let you know, I drive up the hill and back down. As yours, the slopes are between 20 and 30 degrees.
I'm sure mine aren't as long as yours...maybe 70 to 90 feet. You might find out you need front weights..you might find you don't (I didn't). I normally use 2nd or 3rd in low range. If you're driving a gear machine, the only touchy time is declutching. I strongly urge you not to try shift gears in the middle of a slope!
Guess you ought to try both ways, driving up and backing up. As far as your dealer's comments...I agree with the possibility of the mower drifting sideways (depending on how you got your sway links set) but not enough to "pinch" the tractor or overturn it unless your links are set so loose the cutter hits the rear tires. As far as the mower blades rotating in the wrong direction..nah, I don't think so...
So, give driving up the slope a try. Might not work for you but you won't know until you try it. If you think you'll need suitcase weights, get some..driving with the FEL as a counterbalance is not so hot.
Let us know how it works for you.
   / Mowing in reverse on steep hills #6
Hi, I have about 20 to 30 degree slopes that I brush hog with a ford 1320 doing what you are saying backing up and going down forward. It works fine doing it that way. I use to have ford 1220 (smaller framed tractor than 1320) And the tractor actally went better backing up the hill and then driving down, I thought maybe the extra weight of the rotary cutter gave it more traction.
Well that's my 0.02 cents worth. Just thought this might help you.
Ryan
   / Mowing in reverse on steep hills #7
A tractor should have either an internal "overrunning clutch", or if operating a rotary cutter, an external one. If the pto turned in reverse, this clutch would just slip and not turn the driveshaft.
Thanks everyone! Great suggestions. I thought that this stuff about reversing will cause the PTO to go backwards seemed kinda lame /forums/images/graemlins/tongue.gif
Also, turning at the top of the hill is not an option - the slope keeps going past the pasture. I also decided that shuttle shift or HST is the safest way to go. Like someone said - I prefer not to be shifting in the middle of the hill. Its a couple hundred feet down with no flat area in site! /forums/images/graemlins/blush.gif
   / Mowing in reverse on steep hills #9
You should be ok doing what u want on the hills. just take it slow. also ask that dealer what happens when u put a rear snowblower on the back and drive backwards all the time, guess that means it turns into a snow sucker.
   / Mowing in reverse on steep hills #10
The brush cutter will cut properly going in reverse. The pto shaft and hence the cutter blades always rotate in the same direction no matter whether the tractor is going forwards or backwards.
Two safety things.
If you do not have a fel on the tractor, you will have an unbalanced tractor with a cutter on the back (when you lift it). The general rule for going up or down hills with an unbalanced tractor is to keep the heavy end uphill. That means backing up the hill will actually be the safer method, for center of gravity and balance purposes, if you ever have to lift the cutter or if a bump or hole causes the cutter to lift off its wheel.
I can visualize a side slip scenario if you were backing up diagonally instead of straight up the hill. It is possible the cutter could start to slide down the hill and pull the tractor with it. You could slip into a diagonal position inadvertently if the grass is wet and your tires slip. Just stay off hills when they are wet and make sure you go as straight up as possible. And WEAR your seatbelt.
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
1263 (A50490)
1263 (A50490)
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
