MOWING - Hustler Z Diesel (SHIBAURA) QUESTION
   / MOWING - Hustler Z Diesel (SHIBAURA) QUESTION #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
Hoping I'll get a quicker response here ... I have a Hustler Z Diesel with the 25 horse 3cyl Shibaura 1.7L diesel ...(I believe) same diesel as in the Ford / NH / Tier4 LS tractors.
Unfortunately I bought this mower used, so I don't have the owners & engine manual. I'm trying to cross-reference all my filters so I can service it tomorrow. I've downloaded the owners & service manuals for the mower, but it says to refer to the "Engine Service Manual" for the engine, and I can't find that anywhere.
So, does anyone know the oil filter part number, and/or aftermarket filters that will work? Is there a specific oil weight that is recommended for this engine? What is the oil capacity?
Also, same goes for the hydraulic & fuel filters as well.
Side question: Does anyone have a preference for blades? Should I stick with the standard blades, or go with a "hi-lift" or even "gator" mulching blades? I'm due for a sharpen anyhow, and the blades are pretty beat up.
Thanks in advance!
   / MOWING - Hustler Z Diesel (SHIBAURA) QUESTION #2
While not many guys over at Lawnsite run the diesel SZ, plenty run Hustlers and may help you out. Your engine is 1.13L according to Hustlers specs-
"Manufacturer Shibaura
HP 25HP - Shibaura
Displacement 1,131cc"
Here is a link to the general service manual-
http://www.hustlerturf.com/images/product_manuals/115164.pdf
The owners manual says to use SAE20W-50 SL/SM motor oil for the hydro's (which are Hydro gear pumps and Parker TG0335 wheel motors) (section 4-2)
http://www.hustlerturf.com/images/product_manuals/603695.pdf
Complete specs. Says the resevoir cpacity for the hydros is 2 gal.-
http://www.hustlerturf.com/images/SpecSheets2014/DieselSpecSheet.pdf
My 2012 sales brochure says (on page 33 of that issue) that the SZ diesel takes 5.1 quarts of oil for the engine. To use # 2 diesel.
If you use gator blades, don't waste your time with anything other than the Oregon G6 blades. Most guys who run the SZ's use the std high lift blades for either the older XR7 deck or the newer VX4. Do you know which is on this one? If it is a pre '11 it will be the XR7 I believe.
You might want to read through some of the old posts in this link-
http://www.lawnsite.com/archive/index.php/t-285614.html
I've got the XR-7 deck. I don't think my local hustler dealer carries all the filters for the diesel, he may have to order them. Do you know of any aftermarket filters that would work?
   / MOWING - Hustler Z Diesel (SHIBAURA) QUESTION #4
If the ones on it now are OEM (and even if they aren't), take them to NAPA. They can cross reference them pretty easily.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
2005 OVERLAND TANK KILL TRAILER (A50854)
2005 OVERLAND TANK...
2017 JOHN DEERE  30G (A50854)
2017 JOHN DEERE...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2008 FORD F-450 (A50854)
2008 FORD F-450...
