Mowing Mowing - Acreage Coverage Calculators - custom pasture Mowing
   / Mowing - Acreage Coverage Calculators - custom pasture Mowing #1
skoalman12
TX,TX
2013 5083e
Guys,
I've got a little mowing business going. I'm looking for an efficient way to keep real time data on acres mowed. I've got a 20ft shredder. I've looked at Raven Cruizer II. It looks like it will do what I need, but it's $1,600 +. I'd like to see if there is anything better or cheaper. I'm ok with buying it but want to hear from folks that have done this. Seems like all u really need is distance traveled and implement size. My tractor is a 6115D. So I'm limited on electronics.
Thank you.
   / Mowing - Acreage Coverage Calculators - custom pasture Mowing #2
What are you mowing and why do you need to know real-time data?
Distance and implement size would only be effective if you were 100% efficient with your passes and never had to make any turn arounds? But a simple GPS unit tracks MPH and distance traveled.
While I dont know what you are mowing and why you need realtime, for my mowing and bidding jobs, I use a website findlotsize.com Uses a google satellite map and you just plot the points and it will give acreage.
   / Mowing - Acreage Coverage Calculators - custom pasture Mowing #3
There are distance/gps meter/apps for droid and apple available. Why not use one of them in concert with the phones stopwatch/timer. For sizing purposes, googleMaps should do it.
   / Mowing - Acreage Coverage Calculators - custom pasture Mowing #4
Guys,
Thank you.
A quick rule of thumb is width in feet times speed in mph divided by 10 to find acres per hour but if you want a little more accuracy there are online calculators like this one for example.
Mowing Calcuator | How many acres can I mow in an hour
What are you mowing and why do you need to know real-time data? Distance and implement size would only be effective if you were 100% efficient with your passes and never had to make any turn arounds? But a simple GPS unit tracks MPH and distance traveled. While I dont know what you are mowing and why you need realtime, for my mowing and bidding jobs, I use a website findlotsize.com Uses a google satellite map and you just plot the points and it will give acreage.
Mowing pasture, about 1000 acres in one pasture alone. And usually u put in an overlap like 1-2 feet to cover inefficiently using the shredder. It's helpful to know how much you have done on a daily or weekly basis. I have used area calculators on my hand held gps. I can get a pasture size, then keep using it as the day goes along. Then it tells me how much is left. Which Then tells me how much I have done. I just don't think it's that accurate.
   / Mowing - Acreage Coverage Calculators - custom pasture Mowing #6
Ditto I learned that simple formula many years back and it's fairly accurate.
   / Mowing - Acreage Coverage Calculators - custom pasture Mowing #7
And that formula already factors a ~80% efficiency:thumbsup:.
In case anyone finds this thread later I bought the Raven Cruizer II and it works great. I'm glad I purchased it. It's what you need if you are mowing professionally (large acre pastures)
2015 GMC Van (A47384)
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
John Deere (A50322)
John Deere (A50322)
2024 Polaris Ranger 1500 (A50514)
2024 Polaris...
2019 Chevrolet Cruze Sedan (A50324)
2019 Chevrolet...
