mowers.
   / mowers. #1
gravelman
Platinum Member
NH
Kubota 2650
Hi folks...what do you recommend for a mower that is rugged enough to cut a field, high grass. I have a brush hog but it never cuts clean and neat as it is not designed for that. ive seen sickle bars enough and flail mowers. Are the 3 blade finish type mowers capable of mowing thick grass etc.?? thanks
   / mowers. #2
I'm running a 72" land pride 3 blade rfm. I let my grass grow up to 12-24" before cutting it down to 4". But I'm in the sierra foothills so while the grass can grow tall, it's not very thick or wet.
   / mowers.
ok on that, thanks much maybe some dealer would let me try one out..
   / mowers. #4
If ground smooth no sapling etc. and you want somewhat gulf coarse look finish mower,but it will take longer to cut compare to flail mower.
   / mowers.
Ok on that..don't care about golf course look but brush hog leaves uncut areas and not a clean cut look... and i understand it is not supposed to... thanks
   / mowers. #6
assume you keep your current blades sharp (for a bh) and straight, not bent & bunged up
   / mowers.
yes in fact brand new blades and still get a unfinished look. I usually go over some parts more than once. Maybe im driving too fast
   / mowers. #8
Have you try mowing using 3/4 of the deck,also mow one way than back the other?
Think the travel speed might be the issue?
   / mowers.
yes,i overlap all the time. i believe you are right about the speed...im impatient.
CAT Skid Steer (A50322)
CAT Skid Steer...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2007 Ford Taurus Passenger Car (A51694)
2007 Ford Taurus...
2008 Ford F-250 4x4 Pickup Truck (A50323)
2008 Ford F-250...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
2015 Kubota L2501 (A50120)
2015 Kubota L2501...
