Mowers
   / Mowers #1
charlton289
Hurt Va.
2016 massey ferguson GC 1705
I have a question for anyone I have a GC 1705 and the other day I had to mow my MIL yard and her grass was about 1.5 ft tall and it gave my tractor a good workout. I was wondering if I could get a bush hog and knock the really tall thick grass down and still have the mmm on because l don't have a trailer or truck that will carry both separate but I can do it together on my borrowed trailer. My tow vehicle is a 01 Dodge Durango with the 5.9 in it. I have no problem pulling without a bush hog but I don't think the extra weight will make that much of a difference. Thanks for any input.
   / Mowers #2
Should be fine as long as you get the weight balanced properly.
As an aside it would work better to bush hog it and then wait a week for it to dry before you go back in - it will be a lot easier to chew up with the finish mower.
   / Mowers #3
I have to agree with creamer, it should work out fine. I also agree on the aspect of brush hogging the tall stuff first, let it sit and dry about a week or so and come back in and mow again. The dry grass will not be near as hard on your tractor and mower. If you get a brush hog, be prepared to put quite a bit of throttle to the tractor and in tall grass the brush hog will probably pull pretty hard.
   / Mowers #4
What I do with my 2310 when trying to "reclaim" lawn is to go over it the first time with the MMM in its highest --or near that-- position. Works well as a poor man's bush hog, even up to small trees (<2" diameter). Then go back with MMM set to a normal level a week later.
I've also removed my "flapper-damper" thing on the MMM output, which seems to do a great job of really scattering clippings. I start in the center, more or less, and go in a left circular pattern, "blowing" clippings to the outside. Seems to work very well.
   / Mowers #5
I agree with irvingj -- Just use the MMM at the very highest setting and latter make the second pass with it set lower. Unless you have a lot of tall stuff and/or brush (and that on a regular basis) I don't see a need for a bush hog.
2007 INTERNATIONAL PAYSTAR 5600I (A52472)
2007 INTERNATIONAL...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
Ford Flat Bed (A52377)
Simpson 3400 PSI Pressure Washer (A51573)
Simpson 3400 PSI...
