Mowing Mower won't stat up
   / Mower won't stat up #1
jdm58koa
I have a 2305 JD with a 62" belly mower. My son was using the mower today and got off for something . When he tried to start the mower back up , it would not start. I cannot find any fuses?? Does anyone have the answer. Hate to have to go to JD as it will cost me an arm and leg.
Jdm 58 KOA
   / Mower won't stat up #3
jdm
:welcome:
I too suspect that your son just shut the key off, without shutting off the mower deck PTO. Then that switch may still be "engaged" which will cause a "no start" situation. Have had it happen before, and it is very frustrating because it is so subtle. Felt foolish when finding the problem.
I must have not been clear in my post. The tractor will start and run but the PTO will not engage. I wonder if there is a fuse that is shot. He may have stopped without shutting off the PTO??
Jdm58koa
Kubota SVL75-2 (A50120)
Kubota SVL75-2...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
Skid Steer Stump Grinder (A50515)
Skid Steer Stump...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
