Mower suggestions for JD 2520
   / Mower suggestions for JD 2520 #1
Rand
I have several large fields of bet. 3 and 5 acres that require occasional mowing. In the past a local farmer would mow for hay, but with his herd reduced in size no longer has need for it. I do have a 4 ft. rotary mower that works well but takes forever and a day. Plus it's a rough cut, and leaves a lot of debris on top. I was thinking of getting a finish mower; something like 50-72" in size. The land mowed is debris/rock free, and I would never use a finish mower in an area that's questionable. Does this make any sense? Also, if a finish mower does make sense for my needs, is there a particular brand that anyone could suggest thats well regarded for performance and durability?
   / Mower suggestions for JD 2520 #2
I was sort of in the same boat a few years ago. I used a farm king 72" mower behind my 2305 and jd2320. It worked so well that the "field" is now just part of our yard. I now mow it with my z465. I doesn't take long for the grass to start looking better year after year.
   / Mower suggestions for JD 2520 #3
That is a lot of grass to mow with a six foot finish mower. You say several fields let's say three for our discussion that is 10-15 acres to mow, Wow. With a finish mower you will need to mow at least every two weeks. I don't think I would want to try that, but if I was, I would start shopping for a good used 72 inch three point mower for the 2520. Something you could re-sale after a year if you decide, "This ain't going to work" and not take a bath like you would if you purchased new.
   / Mower suggestions for JD 2520 #4
That's good advice.
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
2005 Pierce Enforcer Special Operations Fire Truck (A50323)
2005 Pierce...
KJ Double Ply Polyester Webbing Sling (A50121)
KJ Double Ply...
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
2004 Dodge Ram 1500 4x4 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
