Rotary Cutter mower sizing question
   / mower sizing question #1
SW Washington state
I just bought a Yanmar 3220D, and depending on which specs you read, it is either a 32 or a 35 HP engine. I need a brush hog, pretty much right away, and I was wondering what size of mower this tractor can reasonably run. I found an older 6' mower in good shape on Craigslist not far away for $625, but his ad says it is for 35 HP and up, which would put my tractor right at the bottom end of being able to use it. Usually I would rather have a little more "slack" than that. Is it reasonable to expect this tractor to run a 6' mower comfortably? The PTO is a four speed, if that helps me out at all.
thanks!
   / mower sizing question #2
Your tractor is probably a 32 hp. The higher figure is the gross hp, a useless real world figure. But even a 30 hp should run a 6 ft mower.
thanks. I've been reading all the related threads I can find, and it looks like some of the issues with smaller tractors and larger mowers are not just about the HP required to spin the thing, but also the weight of the tractor and the lifting capacity of the three point. In those areas, I think I've got room to spare. And I rarely cut anything much tougher than blackberries and other soft brush anyway. I'm not usually trying to take down saplings of any size with the mower.
   / mower sizing question #4
If the mower is close by, maybe you try it first.
   / mower sizing question #5
Agree...Your PTO hp is probably about 30; should be ok to run a 6' mower.
I had seen the 3220D data there, and they didn't have much information about it, but I had not seen the mowing with tractors article. Thanks.
well, for now it ends up not mattering anyway, the guy sold the mower a while back and never took his ad down..... :-(
2015 Ford F-550 Auto Crane 4004EH 4,000LB Service Truck (A48081)
2015 Ford F-550...
71059 (A49346)
71059 (A49346)
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2015 Ford Taurus Sedan (A48082)
2015 Ford Taurus...
1998 Ford F800 Water truck (A49461)
1998 Ford F800...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
