Mower question - Bent crank?
   / Mower question - Bent crank? #1
tillboy2001
I think I know the answer already, but before I sell it cheap, I thought I'd run it by you all. I hit a metal pipe while mowing with my walk-behind mower (21" Craftsman with 6HP Briggs and Stratton engine). It bent the rod the blade is attached to and so now you can barely turn the blade by hand and you can forget about starting it. The blade attachs to the end of the crankshaft, correct? So essentially what I bent is the crankshaft going up into the engine. Right? If that's the case, I'm going to sell it off cheap. I already have a new mower and this one has been sitting around. But I really didn't want to 'give it away' if it was only going to cost $40 or $50 to fix. Thanks
   / Mower question - Bent crank? #2
Yes,
Crankshafts arent hard to replace, just quite involved, youll get to know the engine well when its in 1 million pieces on the bench.
Have you thought about costing up parts, might not be really all that much if you install it yourself.
   / Mower question - Bent crank? #3
Be nteresting to know if Sears will have that part, or if you have to go through B&S?
Maybe a parts store on-line if the length of the crank can be determined and spec'd out. Worth a look-see anyway, IMO. /forums/images/graemlins/wink.gif
   / Mower question - Bent crank? #4
Sure Sears would have the part (kind of) when you order a part from them in most cases the order goes right to the manufacture of that part (talking about this type of thing), then they drop ship it to you.
In any case... I would think it isn't much worth fixing the engine. There could be things you just don't know about until you open the case and start to take things apart. We know for sure you bent the crank, but what about the rod and so on. A rebuild kit for the motor is around $60 and that just comes with your basic things (rings, bearing, gaskets and so on), I am not sure what a crank would be. You could get a complete engine ready to run for $200 or so and that would be ready to run... OR get a NEW motor for the same cost.
Yeah, it's just a shame because it was in excellent condition. It sits in my basement most of the time. I bought a new Troy-Bilt walk-behind to replace it. I just hate seeing that very clean 6HP Briggs sitting there dead. Oh well. Like you said, no telling what I might find if I open it up...bent rod, etc. Since I already have a replacement, I'll take this one over to the flea market and sell it. I know someone at the flea market will buy it! I figure $35 or $40. Thanks for the replies.
   / Mower question - Bent crank? #6
LOL sorry for the typo... </font><font color="blue" class="small">( OR get a NEW <font color="red">motor</font> for the same cost)</font>
Should had been... </font><font color="blue" class="small">( OR get a NEW <font color="green"> mower</font> for the same cost )</font>
But I am sure you knew what I was talking about /forums/images/graemlins/tongue.gif .
   / Mower question - Bent crank? #7
as for straightening out the crankshaft, shops dont do that anymore. too much of a liability, if the repaired crank fails and comes apart someone could be injured. part out the engine, youll get more $$ on ebay than if you sell it at a flea market. there are lots of good useable parts still on that engine. and you can see how it all works by taking it apart.
   / Mower question - Bent crank? #8
But did you get rid of the pipe so that you don't hit it again? It would be a shame to thrash that Troy-Build!!
   / Mower question - Bent crank? #9
I did that same thing, though with a stump, to a fairly new walk-behind last year. As it happened, I had an older mower with a trashed body but a working engine. I put the good parts together and now have a Frankenstein mower I use as if it were a brush hog. The mounting screws seem to be the same for most B&S engines. In my case, the crankshaft lengths were also the same, but that's where most of the variation seems to be. I had two old engines, but one had a shorter shaft and wouldn't wortk with the good mower body.
Chuck
   / Mower question - Bent crank? #10
I have an old mower in the same boat, really like it better than the self propelled Troy Built that I bought. I am going to order a new crank and gaskets, under $100 total and fix it this winter.
The wife loaned it to her young cousins to mow with, They set the blade height low so they did not have to mow as often and caught a stump /forums/images/graemlins/frown.gif Laziness always winds up costing more money and trouble.
A local lawnmower shop offered to straighten it for $50 but I declined as it seemed to be bent back in the bushing. Crank Straightening tools are available, although cost several hundred dollars.
Ben
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
Tailgate For Pickup Truck (A53117)
Tailgate For...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
Adams 5T HC Spreader (A53473)
Adams 5T HC...
Four boxes of miscellaneous items (A53117)
Four boxes of...
