Mower Project
   / Mower Project #1
Greg_Phillips
Western Kentuky
CaseIH Maxxum 125
Need some opinions here, I am wanting to build a mower in the image of a combine or windrower. What I am think is using 2 or 3 old reel type mowers welded togeather for the header (using a belt to drive the reel off the front axle), a hydrostatic transaxle out of a lawn tractor, and wheels and tires from a lawn tractor.
Now I need opinions on a few things. If I make this like a combine, how do I make the auger in the head to pull the cut grass to the center, and how do I get it to feed into the feederhouse? How about an unloading auger for the grain tank? Lastly, how do I provide power steering to the rear wheels?
Sorry for the length of the post, thanks for the help.
   / Mower Project #2
This is just my thoughts, but I would use rear discharge mowers that had cathers, these would be ducted to auger made from 1" shaft with screw parts cut from 1/6" sheet metal. The same could be done for unloading. You could use a feed auger like they load over head storage tanks.
   / Mower Project
Just bringing this back up to the top. I have done some thinking and think I am going to use an older sickle mower for the cutter bar, and then building a pipe reel. I think I'm going to use a couple of leaf blower fans to move the cut grass to the bin and out of it.
I am still trying to figure out the cross auger in the header, any ideas? Please help me figure this out so I can start looking for the parts I need.
   / Mower Project #4
/forums/images/graemlins/confused.gifWhy???? /forums/images/graemlins/confused.gif
   / Mower Project
You ask "why?", I ask "why not?" The reason I am wanting to do this is because I grew up on a farm, running the combine in the fall was my favorite part of the year. Saddly we no longer row crop, so I'm just looking for a way to have that feeling through out the summer. On top of that I just think it would be something pretty neat to build.
   / Mower Project #6
Why not start out with a "F" series front cut John Deere commercial mower. It's already a rear steer all you have to do then is figure out your header.
   / Mower Project
That would be ideal but not many of them sell around here, the ones that do sell for the price of a new one, or are so worn out that you would have a small fourtune in one to get it repaired.
   / Mower Project #8
You might search for an old pull type Allis All Crop combine. There were a lot of them sitting around the hedge rows when I grew up. As I recall, it had about a six to eight foot header. That would give you the header parts (or frame at least) that you could start with. Hooking it to a power plant like a Excel Hustler would be pretty straighforward, then you could fab the "bin".
Not something I'd want to try, but it sounds do-able.
Ron
   / Mower Project #9
To make your infeed auger Ive made some for grain tanks out of old unloading augers of conbines you can usually find a right and a left side that are worn the same. I know of a nice matched set of augers is the top leveling augers on top of a deere cotton picker work well to. you could mount a sprocket in the middle of the screws and use a chain and paddle conveyor off a combine for the back feed funtion.
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
2019 FORD F-150 (A52472)
2019 FORD F-150...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2001 TRIPLE E INDUSTRIES 3-AXLE STEP DECK 48X102 (A52472)
2001 TRIPLE E...
